Drives: 2016 Camaro 2SS Join Date: Aug 2009
BMR Suspension Releases New Product 5th Gen Camaro/S197 Mustang/4th Gen Camaro Solid Motor Mount Upgrade Kit MM006 Eliminate engine movement and maximize throttle response in your 2010-Up Camaro, S197 Mustang, or 4th Gen Camaro with a Solid Motor Mount Upgrade Kit from BMR Suspension. These motor mount bushings are constructed from 6061 billet aluminum and are designed for max-effort performance applications. The BMR Solid Motor Mount Upgrade Kit (PN MM006) eliminates engine movement by replacing the polyurethane bushings from the MM004 motor mounts, all BMR S197 Mustang K-members, and the KM005 and KM019 Camaro K-members. Installation time is 2-3 hours with stock exhaust manifolds (install time may be longer with aftermarket headers). Available in black anodized finish. To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055. ![]()
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
Yes! Engine movement is wasted torque. By reducing or eliminating that unnecessary engine movement (either by polyurethane or solid mounts), you have a more direct application of that torque to your drivetrain. Will you feel that improved throttle response while driving normally on the street?.....probably not. Will it make a difference at the drag strip while doing max effort launches....yes it will.
| Tags |
| bmr suspension, camaro, motor mounts, solid motor mounts camaro |
