Old 08-01-2014, 04:41 PM   #1
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
20x10.5 Front offset
I have been trying to confirm offset for a 10.5 front/back setup (I am OCD).
I trawled through various forums and websites and came up with these variations.
20x10.5 5x120 +35 front (Niche Apex/Milan) 315/35/20 rear and 275/40/20 front tires
20x10.5 5x120 + 25 machined to +27 (Rohana RC-5)
20x10.5 5x120 + 24 (BBS) - not sure if this worked out.
20x10.5 5x120 + 27 (Vossen CV3)
Tire size would be close to if not 315/35/20 rear and 275/40/20 front.
Which of the above would require no spacers, no rubbing (not lowered) and be flush with the fender?
ajp is offline   Reply With Quote
Old 08-03-2014, 08:31 AM   #2
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
I believe the exact offset will vary based upon the wheels you choose. Any vendor or the wheel manufacturer should be able to tell you what you need to make the wheel fit guaranteed. If you can't get them to guarantee the fitment then you should find another place to buy. Also, I am not sure if a 275 tire will fit on a 10.5" rim. Looking at the recommended tire size stickie that rim should run a 305-315
RolltideSS is offline   Reply With Quote
Old 08-03-2014, 10:38 AM   #3
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
A 275 absolutely fits a 10.5. It's slightly stretched, but it works.
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Airlift Suspension V2
Niche Targa 20x10.5
Chris14RS is offline   Reply With Quote
Old 08-03-2014, 01:15 PM   #4
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
20x10.5 with 35 I dont think will work up front.I have 1/4" clearance with 20x10s with 35 offset and 285/35 tires and 1.2 negative camber with coilovers that give me 10mm extra clearance.
VR Baron is offline   Reply With Quote
Old 08-03-2014, 01:37 PM   #5
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
I'm putting 20x10.5 +35 niche targa all around with 275-35-20, but I'm bagged.
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Niche Targa 20x10.5
Old 08-03-2014, 02:16 PM   #6
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
20x10.5 with 24 offset works thats what i run with 295 nittos invos for the front
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 08-04-2014, 09:51 AM   #7
Installer.613
Drives: 2010 Camaro 2SS/RS , 1967 camaro SS
I'm running Niche GT5 20x10.5 with a +20 up front with 275/40r20 NT05
Installer.613 is offline   Reply With Quote
Old 08-05-2014, 03:17 AM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
None of those will fit the way you want.
SUX2BU is offline   Reply With Quote
Old 08-13-2014, 02:05 PM   #9
ajp
ajp's Avatar
So worst case with 20x10.5 5x120 +35 front with 275/40/20 front tires is that I might need spacers to get the wheel flush?
Old 08-13-2014, 02:18 PM   #10
Moreno1
Drives: G5.R
The BBS offset worked out with 295 tires in front.
Moreno1 is offline   Reply With Quote
Old 08-13-2014, 02:25 PM   #11
ajp
ajp's Avatar
I love those BBS wheels.
An offset of +35 I am limited to 275/40, but an offset of +20 lets me run 295 tires?
Old 08-13-2014, 02:53 PM   #12
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
35 up front. Really depends how low you are. I'm on bags 20x10.5 35 275/30
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Niche Targa 20x10.5
