08-02-2014, 07:32 PM | #1 |
Drives: 2010 SS LS3 S200 56/61 AGP TT Join Date: Jan 2009
AGP TURBO- Rubbing on decel
Hey guys
I have the AGP TT kit and no cold air intake. Does have meth injection tho. So here's the problem- I have a "rubbing" noise with the throttle closed, but with the throttle open (5-100%) the noise is gone This is my first turbo car and I can't rememeber if it made this noise after install Just driving this like this can't be right. Is this a mechanical problem it tuning? |
08-02-2014, 09:21 PM | #2 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Do you get the noise when the car is at idle or is it when the turbos are providing boost and then you close the throttle? If it is the latter it may be the sound of boost pressure releasing through the blow off valve. When the throttle closes quickly and there is boost in the intake tube it must be released through the blow off or it would back up the turbos.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
08-02-2014, 11:54 PM | #3 |
I understand what you are saying.
Unfourtianetly it is at without boost pressure. It may also happen under boost- can't say I have been under pressure and realising the throttle. Wastegate springs are set at 8-10 psi- or in that range anyways. |
08-03-2014, 11:28 AM | #4 |
Really hard to trouble shoot a noise online. Get under and check to make sure everything is tight. There should be no "rubbing". It could be air filter noise, the BOV, or just the way the turbos sound.
Nick
Corvette Z06 -1200ish rwhp |
08-03-2014, 01:28 PM | #5 |
Drives: All things Turbocharged Join Date: Dec 2010
Just got to try to find where the noise is coming from and loosen something, move it and re-tighten.
08-03-2014, 09:36 PM | #6 |
08-04-2014, 12:23 AM | #7 |
Tune doesn't cause parts to rub. Without knowing what exactly the sound is, it is really hard to say.
Nick
08-08-2014, 07:15 AM | #8 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
Mine had a slight rub on the driver's side on day 1.The adapter from the manifold to the turbo was very close to the heat shield.
08-08-2014, 09:20 AM | #9 |
Drives: 2012 Camaro SS Transformers Edition Join Date: Apr 2013
My rubs also kinda sucks. It's the driver side also. I get a rattle upon letting out of the clutch too I have not found yet. Think it's the heat shield on the manifold rattling.
08-08-2014, 09:57 AM | #10 |
That is just part of the install, adjusting it for clearance. I've seen plenty of them installed and never had any rubbing issues. Just get under the car, and adjust it.
Nick
08-08-2014, 12:55 PM | #11 |
Drives: 2016 2SS Join Date: Nov 2011
Check passenger side AC lines down low.
Who Dares...Wins |
08-09-2014, 07:49 PM | #12 |
Thanks for the info guys.
If I can pin point the noise I will post- |
