Old 08-02-2014, 08:58 PM   #1
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
Pedders 220035's installed
So, after finding one of the last remaining pairs of 35's, and having them before the car arrived, today they went in. Rear end is now level and so far she drives the same. I love the look for sure. Measured almost exactly half an inch lower now in the rear. Must say I'm very happy. Shout out to Dropspeed for the recommendation on these.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 08-02-2014, 10:31 PM   #2
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
If you are changing ride height, you do plan to go in for complete front and rear alignment. Ride height change will mess up caster/camber and toe in front as well as rear since the rear suspension is independent.
Did you scale the car to be sure cross weight is correct and car is balanced?
Kendall421 is offline   Reply With Quote
Old 08-02-2014, 10:46 PM   #3
jksynergy
jksynergy's Avatar
Yes, alignment appointment is for this week. And it will be a more aggressive alignment as we autox and she's not a daily driver. And these are just coil springs, not coil overs.
FB: hangtimeracing
Old 08-04-2014, 07:25 PM   #4
1leNPP
Drives: 1LE , 1SS , NPP
They look a lot like ZL1 rear springs to me and the ZL1 rear spring lower the back of the car a 1/2 inch to.http://www.camaro5.com/forums/attach...1&d=1344259390 . the ZL1 rear spring is on the right hand side in the pic.
1leNPP is offline   Reply With Quote
Old 08-04-2014, 07:48 PM   #5
jksynergy
jksynergy's Avatar
They do look similar. The main difference being the Pedders are linear in rate vs. the ZL1's being progressive.
FB: hangtimeracing
Old 08-04-2014, 11:51 PM   #6
1leNPP
With the 3 coils wrap close together at the top of the spring and the other space out not so sure that a liner rate spring you got .
Old 08-05-2014, 07:46 AM   #7
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
These are the same as the Apex springs, and they are progressive sir.
Edit: Post #65 confirms they are progressive.
http://www.camaro5.com/forums/showth...=358137&page=3
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 08-05-2014, 08:22 AM   #8
jksynergy
jksynergy's Avatar
Actually, Apex uses the PFadt springs, not Pedders.
Pedders are linear in rate, same as factory.
Post #7 and on down.
http://www.camaro5.com/forums/showth...ht=zl1+springs
FB: hangtimeracing
Old 08-05-2014, 08:49 AM   #9
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Oops, sorry man you are 100% right.
Old 08-05-2014, 08:54 AM   #10
jksynergy
jksynergy's Avatar
No worries.
FB: hangtimeracing
Old 08-05-2014, 08:57 AM   #11
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Looks great!
Old 08-05-2014, 09:36 AM   #12
jksynergy
jksynergy's Avatar
Originally Posted by Dropspeed View Post
Looks great!
Thanks Matt.
FB: hangtimeracing
