Old 08-05-2014, 10:05 PM   #1
jiannotto9492
Drives: 2014 Red 2LS
LFX and E85
I can fill up with E85 without a problem right? Just want to make sure I don't need to play around with anything to make it run on E85.
jiannotto9492 is offline   Reply With Quote
Old 08-05-2014, 10:13 PM   #2
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
I don't believe the LFX engine is designated as flex fuel engine. Otherwise I would think the cap and or window sticker would designate as such. I don't have my manual any more as my daughter now owns our previous 2014 V-6. If I recall though the manual stated not to run anything higher that 15% ethanol.
RobertRS is offline   Reply With Quote
Old 08-05-2014, 10:34 PM   #3
jiannotto9492
http://gmauthority.com/blog/gm/gm-engines/lfx/
According to here it has E85 capability.
Old 08-05-2014, 10:37 PM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
capability yes, not recommended- NO, just means that the components are ok for ethanol. would need a recal for it to work.
Old 08-05-2014, 10:38 PM   #5
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
DO NOT PUT E85 IN YOUR CAMARO.
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 08-06-2014, 09:34 AM   #6
schwartzeneger
schwartzeneger's Avatar
Drives: 2013 Crystal Red Tintcoat
The search button is your friend . Short answer is yes, but you need to get a tune, or a sensor to actually take advantage of it. Possibly new injectors and pump.
http://www.camaro5.com/forums/showthread.php?t=367911
schwartzeneger is offline   Reply With Quote
Old 08-06-2014, 07:00 PM   #7
jd10013
Drives: 2012 camaro
the engine is E85 compatible, the fuel system isn't. they designed the engine to be E85 capable so they could use it in other vehicles. the camaro isn't designed for it though.
jd10013 is offline   Reply With Quote
Old 08-06-2014, 07:02 PM   #8
KMPrenger
KMPrenger's Avatar
It is not tuned for E85, nor does it have a sensor....so DO NOT DO IT.
If you tune the car for E85, it can be done, but the moment you wanted to go back to gas you'd have to re-tune it.
Old 08-06-2014, 07:46 PM   #9
Gilly Monster
Drives: '14 2SS/RS
Having experienced running E85 in my previous car (STi) and the upgrades / mods required to run it (fuel pump/lines/injectors/tune); unless you have a way of changing maps quickly (between tanks or on the fly) you are going to find it annoying as hell to drive even around town. Also you will generally, in my experience, have much lower MPG with E85 and any slight savings in price are quickly offset by more frequent fill-up, and usually out of the way fill up locations. You will see HP and TQ gains from E85, but at the cost unless you just want a corn-fed drag car, I don't think its worth it IMO.
Gilly Monster is offline   Reply With Quote
Old 08-07-2014, 05:44 PM   #10
Dale_K
Drives: 2014 1LS
I think cars capable of using E85 have a yellow fill cap with the words "E85/Gasoline". I just checked my garage and my 2012 Chrysler has the yellow cap while my 2014 1LS has a plain black cap.
Dale_K is offline   Reply With Quote
Old 08-08-2014, 09:33 AM   #11
AndrewMinhas
AndrewMinhas's Avatar
Drives: 2014 1LE
I have the lfx engine and put e85 in it once in awhile.
Things you'll experience and notice:
Sometimes the check engine light will come on and also when you try to start the car it will require you to hold the ignition an extra half second or so. But as far as driving it will run fine and as for mpg it will get significantly less because it's hard to stay off the gas because it feels a lot stronger. It could be a placebo effect as far as power but I'm almost certain it has more power.
AndrewMinhas is offline   Reply With Quote
Old 08-08-2014, 09:42 AM   #12
SubSonic
SubSonic's Avatar
Drives: 2014 SS/RS M6
In all honesty though, that really isn't a good idea. The fuel system is not designed for it. You may be putting premature wear on rubber components due to the even higher alco-content. Generally it's going to be rough on the fuel system. Granted, the motor can handle it... but I wouldn't trust the stock tuning to be doing you any favors while running it.
SubSonic is offline   Reply With Quote
