Old 08-06-2014, 08:03 PM   #1
ba2ss
ba2ss's Avatar
Drives: 2012 2SS/RS M6
rant about oil capacity in the ls3
hello my Camaro brothers and sistas, you guys are awesome.
As Jay Leno says, real car guys change their own oil. So of course I change my own oil religiously on all my cars, same way my dad did.
I just want to complain that its redicioulus that the ls3 in my 2012 Ss holds 8 quarts of oil, I just don't get it, maybe someone here can explain to me the justification?
my Silverado, even though its a 5.3, only holds 6, I mean this is a truck engine, so why 8qts in the 6.2?
ba2ss is offline   Reply With Quote
Old 08-06-2014, 08:07 PM   #2
Mean Green Z28
Drives: 2010 2SS
Longer service intervals? Wont run out of oil for long periods of high rpms? Oil cooler?
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 08-06-2014, 08:16 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You ask why 8qts? Cause that's what it calls for. EOS.
Felix- speeding in my SS/RS
FSP tuned: 377/389
Old 08-06-2014, 08:17 PM   #4
ba2ss
ba2ss's Avatar
yeah, totally get not starving the engine while racing, 8qts still seems excessive, I'm sure there's an engineer that has the ratios/formulas that justify, either that or gm made a deal with mobile 1�� any one know about the capacities in the challenger/mustang, are the comparable?
Old 08-06-2014, 08:20 PM   #5
ba2ss
ba2ss's Avatar
looking for more of a technical reason, not just "that's what the owners manual says"
Old 08-06-2014, 09:11 PM   #6
Synner
Drives: cars
How about corvettes that exploded with 6. Adequate oiling is such a drag.
Old 08-06-2014, 09:14 PM   #7
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Well, next time you do the oil change only put in 6 quarts and find out what happens. Im sure that will give you the answer you are seeking for.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 08-06-2014, 09:22 PM   #8
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Why do they put deep sump oil pans on race cars? GM did you a favor and saved you money in the future by not having to add another oil pan!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 08-07-2014, 12:54 AM   #9
Avenging Orange
Avenging Orange's Avatar
Again, shoulda known this before you signed the papers. I think Civics take 4.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 08-07-2014, 01:38 AM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You must have never owned an LS1.
SUX2BU is offline   Reply With Quote
Old 08-07-2014, 02:32 AM   #11
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Mercedes V6's take 10 quarts...
DSX_Camaro is offline   Reply With Quote
Old 08-07-2014, 08:24 AM   #12
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
My LS1 always took close to 7. So 8 is not that big of a stretch for me. Granted the LS1 I had used a little (no leaks, no blue smoke), but it never starved for oil under load either.
I think it is mostly to keep us from grenading the engine under "spirited" (define as you see fit) driving.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 08-07-2014, 09:59 AM   #13
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
There isn't much oil at all running through your motor at any given time... the reservoir is a heatsink.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 08-07-2014, 10:05 AM   #14
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
Take advantage of the longer OCI available to you with this large sump and modern synthetic oils. You don't say, but you sound like a "3,000 mile" guy. Use M1 or the syn of your choice, run it down to zero on your OLM, then do a UOA to confirm the quality of the oil at that stage. The LS3 is a low stress engine at only 68.7hp/L so is a good candidate for extended oil change interval, probably no more than once per year.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
