So... based on a little bit of research, the "driver's side dim halo" problem seems to be a tough one to deal with. The two solutions I was able find are...
1. http://www.camaro5.com/forums/showth...light=dim+halo - The fix - "Circuit boards for the Halos..... and perfection." 2. http://www.camaro5.com/forums/showth...light=dim+halo - The fix - "Caused by the actual LED chip that powers the ring." Ok so this is good news because I have a solution to the problem and don't have to spend a few hundred $ on an Oracle or Nightowl upgrade. Now, my question is - is the "circuit board" and the "LED chip" they are referring to the same thing? If yes, where can I find one? Camaro5 member MYCAMARO2011 provided this link... http://www.ebay.com/itm/151187141200...%3AMEBIDX%3AIT Is this the fix I need? If so, has anyone had experience with this? If not, what would I need? Thank you in advance.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 2SS Join Date: Apr 2011
So, you are out of warranty?
Edit: Also, the LED that you linked to looks too tall to fit |
No more warranty, correct.
We have a small quantity of the OEM LED's. PM/email me if you want to try that first.
| Tags |
| dim, drivers, halo, side |
