Old 08-08-2014, 01:36 AM   #1
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Anyone try Meguiar's D302 polish?
I am thinking of buying DA microfiber pads with D300, and since the new D302 is the MF version of m205, I would be interested in hearing how D302 handles camaro's clearcoat when paired with a microfiber finishing pad? Before the introduction of D302, it seems most people were using m205 with foam pads as the finishing polish.
Thanks!
Inuyashas_Brother is offline   Reply With Quote
Old 08-08-2014, 11:03 PM   #2
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
If you do use it post up some before and after photos and 50/50 shots for us to see how it works.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 02-16-2015, 05:17 PM   #3
Travis104
Drives: 2014 ZL1
Any reviews?
Travis104 is offline   Reply With Quote
Old 02-16-2015, 07:23 PM   #4
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Originally Posted by Travis104 View Post
Any reviews?
Yes I used this system. The 302 Polish is for removing haze left by the D300 compound. I had only a few panels that required it, you may have less or more as no 2 paint jobs are exactly alike.
I was very satisfied with it.
Lots of videos on you tube how to use it. This is the most informative one.
Oh and make sure to get the proper OPM setting for the machine your using.
Joe M 2012 2SS is offline   Reply With Quote
Old 02-16-2015, 07:35 PM   #5
Travis104
Drives: 2014 ZL1
Thanks. Do you know how it compares to the 105/205? This is the kit I was looking at.
http://www.autogeek.net/da-microfibe...r-kit-5in.html
Old 02-16-2015, 08:15 PM   #6
Joe M 2012 2SS
Drives: 2012 2SS
The 105/205 are more abrasive but are generally used with less aggressive foam pads ie. orange and white.
The D300/301/302 are less aggressive but use more aggressive microfiber pads. You also get no sling at all with microfiber pads, and no dusting with the D300 compound.
I haven't used 105/205 but got this info from Brandon at meguiars customer service, he is great to deal with.
This may be a better price than what you have. Same kit.
http://www.amazon.com/Meguiars-DMCKI...004090-5008720
Old 02-16-2015, 08:46 PM   #7
Joe M 2012 2SS
Drives: 2012 2SS
Here is another video of the cutting of the D300 with the microfiber pad. It finished down like this on most of my car.
I used the 302 polish in the areas that got haze from the D300 and they finished down the same.
Old 02-17-2015, 07:51 AM   #8
Joe M 2012 2SS
Drives: 2012 2SS
1 last video of a car with heavy defects using this system with the DMX cutting pads instead of the DMC.
Old 02-17-2015, 11:11 AM   #9
Travis104
Drives: 2014 ZL1
Thanks for all the videos. It seems like it could be a pretty good system with the microfiber pads. I talked to a tech at autogeek and he said that the microfiber would cause micro marring?
Old 02-17-2015, 11:35 AM   #10
Joe M 2012 2SS
Drives: 2012 2SS
I can't speak for the DMX pad as I only used the DMC because my defects were light to moderate. I got no marring from the DMC pad, only light haze in a few spots that finished down easily with the 302. I did prime the pads exactly as shown and cleaned with a brush every panel. I would tend to think micro-marring would come from improperly prepped surface, improperly primed pad, or very soft paint. And could happen with a more aggressive pad such as the DMX.
This system was designed for the modern harder OEM paints. I have also used it on a friends Honda Accord which had buffer swirls and automatic car wash scratches.
The Honda had softer paint than my Camaro, hazed more, so I used the 302 on the whole car.
No problems.
Here is a review of someone who has used it more extensively than what I have, He did say he had marring on "troublesome" paints.
http://www.meguiarsonline.com/forums...rofiber-System
and another
http://www.meguiarsonline.com/forums...-System-Part-2!!!
Old 02-17-2015, 03:41 PM   #11
Travis104
Drives: 2014 ZL1
I am really confused at this point. I emailed meguires a couple days ago, and they are saying that I should go with a foam pad (these) http://www.autodetailingsolutions.ne...ch-bundle.html
I'm just not sure what pads to use with the 105/205 or the paint correction system. I don't want to make things worse, but I have read so much I think I have confused myself...lol
Old 02-17-2015, 06:28 PM   #12
Joe M 2012 2SS
Drives: 2012 2SS
If your using the microfiber DA correction system on a free spinning DA the DMCKIT5, it has the pads with it, along with the proper backing plate. This was the original kit you posted.
I haven't used the 105/205, lots of people use Orange CG hex logic for compound and white for polish.
What do you already have? If you have the 105/205 you don't need the DMCKIT, just pads and backing plate.
I can't tell you that 105/205 is better or worse than the DMCKIT, all I know is the DMCKIT was very easy to use and gave great results for me.
You'll have to decide which one is best for you.
d302, microfiber pad, polish
