Old 08-10-2014, 05:07 PM   #1
Matts11SS
Matts11SS's Avatar
Drives: 2011 1SS/RS LS3
Heater core replacement
So my buddy and I took it upon ourselves to replace the heater core on his 2011 L99. Dear Lord, this is a hell of a project. Anyone else done this themselves? We have the housing out now with the new core in, about to put this back together. We had the windshield removed and pulled the dash, which is the hardest part. Little bolts here and there holding the housing to the firewall... Wow I hope I never have to do this to my LS3!!
Matts11SS is offline   Reply With Quote
Old 08-10-2014, 05:15 PM   #2
wayne watson
wayne watson's Avatar
Drives: 2014 camaro ss ,1967 chevelle ss,
did you guys read the repair procedure? never have seen a windshield removed to do a heater core. just asking, im going to look it up now..ok disregard my entire post, wtf
wayne watson is offline   Reply With Quote
Old 08-10-2014, 06:34 PM   #3
Matts11SS
Matts11SS's Avatar
Yeah there are 4 bolts only accessible by removing the windshield. It's insanity.
Old 08-10-2014, 07:04 PM   #4
Midnight Rat
Midnight Rat's Avatar
Drives: SS 1LE
Since you have it torn apart, is there any other way of removing this.
Midnight Rat is offline   Reply With Quote
Old 08-10-2014, 07:23 PM   #5
Matts11SS
Matts11SS's Avatar
What do you mean? Removing what?
Old 08-10-2014, 07:30 PM   #6
Scott@Bjorn3D
I believe Ofer has a way to remove the dash without removing the windshield.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-10-2014, 07:33 PM   #7
Matts11SS
Matts11SS's Avatar
I believe it's possible by cutting the bolts... But then you can't put new bolts back in. We did the work following AllData's guidelines. It was a pain, but it was done correctly. And even though we are doing the work ourselves, the warranty is covering everything besides the windshield removal and refit, which was $100. Not bad.
Old 08-10-2014, 07:34 PM   #8
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
I have seen a thread on here somewhere, where you can remove heater core without having to remove windscreen, I believe it involved a die grinder to shorten installed bolts before they were removed from dash that would normally hit on windscreen as they were undone.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 08-10-2014, 07:37 PM   #9
Matts11SS
Matts11SS's Avatar
I don't know how that's possible because the heads of the bolt (3.5 inch bolts) are less than a half inch from the windshield.
Old 08-10-2014, 08:23 PM   #10
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
It's not removing the dash that you have to remove the windshield for. It's the heater core.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
Old 08-10-2014, 08:27 PM   #11
Matts11SS
Matts11SS's Avatar
Correct, technically you are removing the cluster brace that the dash bolts to. It was fun...
Old 08-10-2014, 08:30 PM   #12
Matts11SS
Matts11SS's Avatar
The metal tubing you see here:
Old 08-10-2014, 08:35 PM   #13
wayne watson
wow, that is nuts, i put a heater core in my 93 chevy truck last winter and it took longer to get the hoses off than to get heater core out. what happened? who's designing these things? and is the 14's the same?
Old 08-10-2014, 08:42 PM   #14
Droptopscott
Droptopscott's Avatar
Drives: 2014 1lt rs convertible
I work for a Chevy dealer and I've had to do one on a 2013 with 1,000 miles on it. It was a pain but not too bad of a job. Warranty only pays like 6.8 hours if I remember correctly
Droptopscott is offline   Reply With Quote
