![]() ![]() Drives: 2012 SS LS3 Join Date: Nov 2011
Tore the axle shaft boot, now what?
Saw some grease on the inside of my rear wheel. Upon investigation it looks like a plastic collar from my LSR end links was rubbing on the axle shaft outer rubber boot. The boot is torn and spewing grease. My question is can I just replace the boot and somehow repack the bearing with grease or do I need replace the axle. If I need to replace the axle, will the stronger 1LE axles bolt right into the stock differential and wheel hub?
Thanks for the help.
Buttonwillow 2:23.736
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 Last edited by Cuda7050; 08-10-2014 at 11:56 PM. |
Drives: own more cars than i can list Join Date: Nov 2010
you can replace the boot, we have a kit for 30.00
Great to know a low cost repair is an option, thanks.
Sacramento Raceway 12.89 at 112 mph Thunderhill 2:22.242 |
