Old 08-14-2014, 03:46 PM   #1
stoopid
Drives: 4 wheels
Stage 2 - upgrading tweeters
I've added a sub to my stock stereo. Things have improved a lot.
http://www.camaro5.com/forums/showthread.php?t=370906
There's still some harshness from time to time in the higher frequencies. I'm starting to be convinced the tweeters in the stock component setup aren't very good, and the cause of the issue.
These should be relatively easy to drop in a new pair. I did a search of the forums and see a variety of ideas, but no definitive "these sound best and fit perfect". It also appears no one has tried this recently so perhaps something new has come along...
For the record, unless absolutely necessary, I'd like to avoid pulling the inside door off to replace the entire components. The mids from the stock 6.5" is fine. I'm really just looking for a better set of tweeters. I'm willing to spend $50 on a decent pair if they exist at that price point.
stoopid is offline   Reply With Quote
Old 08-14-2014, 11:15 PM   #2
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
You can replace the tweets by prying the triangle panel they're on straight up. 1-1/2" diameter is your limit before customization. I installed pioneer ts-t15 for about $36 shipped. They are a soft dome that gets rid of the annoying highs that metallic domes cause. See my journal for more info.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 08-15-2014, 05:57 AM   #3
stoopid
Drives: 4 wheels
Cool, I looked at your write-up. From what you posted, cutting the holes was personal preference, but those could have mounted without the hole being drilled (?).
I'm going to need to get a hot glue gun or maybe use some epoxy I already have. Any cons I'm not aware of using epoxy? [other than permanence]
Also, I noticed a nice set of Infinity tweeters for $45 shipped on Amazon, came with mounting hardware, etc. But it was 2ohms. Will that really make a difference with a tweeter?
Old 08-15-2014, 02:29 PM   #4
stoopid
Drives: 4 wheels
Got impatient and picked up a pair of JL Audio C2 tweeters for $100. Install just needed some hot glue. They sound awesome, crisp but not tiring. Tried a few tracks I had issues with before and don't hear any problems now.
http://www.amazon.com/JL-AUDIO-C2-07.../dp/B004CT34SA
Old 08-23-2014, 07:34 PM   #5
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Hmmm interested in this as well
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 08-23-2014, 10:54 PM   #6
crabapple
crabapple's Avatar
Drives: '12 ZR1
I just bought a set of these and look forward to installing them......
crabapple is offline   Reply With Quote
Old 08-25-2014, 06:08 AM   #7
stoopid
Drives: 4 wheels
These and the 10" sub have brought this system to life. They're awesome tweeters, crisp without ANY harshness. I wired in the crossovers that came with them, then ran a few frequency tests and sweeps and made sure there were not any frequency drops - everything tuned just fine! With the sub, the head unit I'm using Treble 0 , mid -5, bass -6. The sub's crossover is around 80-100hz. That depends on your ears and style of music. But those EQ numbers are about right to reduce the bass being sent to the factory speakers while still allowing the sound to be full. The sub just catches anything you want to have some extra punch like kick drums, floor toms, bass guitar, and low synths.
Old 08-30-2014, 11:40 AM   #8
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
You know, the sub handles the missing bottom just fine, but, yeah, the highs need some work. Thanks for the post!
Anyone have opinions between the two referenced?
sjmautoprod is offline   Reply With Quote
Old 08-30-2014, 02:08 PM   #9
TwentyTen2SSRS
Drives: 2010 2SS/RS
Yeah I am looking for some new tweeters looking forward to hearing
Old 08-30-2014, 02:21 PM   #10
crabapple
crabapple's Avatar
Drives: '12 ZR1
Mine were just delivered. Plan on doing the install Monday and will post my thoughts.
Old 12-25-2017, 07:17 AM   #11
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
How'd it go/sound?
blackswan is offline   Reply With Quote
Old 12-25-2017, 10:01 PM   #12
Dega Man
Drives: ZL1
Good choice
Dega Man is offline   Reply With Quote
