Old 08-15-2014, 12:48 PM   #1
Natti337
Natti337's Avatar
Drives: 2014 Chevy Camaro LT
car shakes a little when parked is this normal?
I have a 2014 Camaro LT that I purchased brand new about 3 weeks ago. Lately I've noticed this little shake I guess in the motor and it is stronger initially when the car is turned on but you can always feel it when it's on park. I don't know how to explain it but it's like the car is fine for a couple seconds and then a little tremble happens and then fine again and then another tremble.
Is this normal for these cars? Most newer cars that I've been in you can barely even feel that the car is on so I don't know if this is just a camaro thing because it's more powerful?
thanks
Natti337 is offline   Reply With Quote
Old 08-15-2014, 12:53 PM   #2
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
My SS does it, but that's because it has a huge engine. Never driven a V6
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 08-15-2014, 12:56 PM   #3
bucolic
bucolic's Avatar
Drives: 2014 Camaro SS/RS Crystal Red Tintc
My V6 2LT with M/T I had did not shake at all at idle.
I traded it for a 2SS with M/T and it does have a little shake at idle.
2014 Camaro SS/RS Crystal Red Tintcoat
bucolic is offline   Reply With Quote
Old 08-15-2014, 12:59 PM   #4
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
My car seems to run a bit rough on cold starts but only when I'm running 87 gasoline. I run 91 most of the time and never noticed anything since then
TommyTheCat is offline   Reply With Quote
Old 08-15-2014, 12:59 PM   #5
beasstmode
Drives: 2011 camaro ss
+1
On my ss yeah, it shakes a lot compared to a lot of other cars. I work at a dealership and have driven a lot of the v6 models and I can say they do slightly but nowhere near as bad as the 6.2l. Now compare the v6 camaro and the 370z, the camaro feels like it has a lot more shake to it.
beasstmode is offline   Reply With Quote
Old 08-15-2014, 01:01 PM   #6
J-Crazy Camaro
J-Crazy Camaro's Avatar
Drives: Red V8
you may have a bad cold start injector. does it happen when the car is hot? Or do you have a malfunction light on anywhere?
J-Crazy Camaro is offline   Reply With Quote
Old 08-15-2014, 01:02 PM   #7
Phail
Phail's Avatar
Drives: 2011 2LT/RS M6 IOM
Can't say I could feel the vibrations just sitting in the seat - but you can definately see/feel it in the shifter nob on my 2LT/RS M6 (Direct connection to the engine 4TW)
The car will always high idle on a cold start and be more loud / vibrate more - takes about 30 seconds to go down to low idle, at which point you cant feel or hear anything really (stock mufflers are way to quiet!)
Phail is offline   Reply With Quote
Old 08-15-2014, 01:04 PM   #8
TheGhosty
TheGhosty's Avatar
Drives: '11 SW 1LT RS
Did you buy your car new? Kinda sounds like the ghost cam you can add via tune.
TheGhosty is offline   Reply With Quote
Old 08-15-2014, 01:05 PM   #9
Natti337
Natti337's Avatar
no malfunction lights and yes it happens when the car is hot also.
Old 08-15-2014, 01:17 PM   #10
6 gun
Drives: 2010 ss 6 gear
my ss has the shakes..... took it to the service dept. and they said it was how the direct injected operate
6 gun is offline   Reply With Quote
Old 08-15-2014, 01:21 PM   #11
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
Your SS is not direct injected.
RobertRS is offline   Reply With Quote
Old 08-15-2014, 01:25 PM   #12
mrpyle
mrpyle's Avatar
Drives: 2011 2LT/RS - Synergy Green
thanks
Only time I notice anything close to that is when the ac is on. Compressor kicks in, and idle changes. That's about it ....
mrpyle is offline   Reply With Quote
Old 08-15-2014, 01:26 PM   #13
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
My guess is fuel evap canister getting purged. It purges the fumes for a few seconds then closes the valve, causing rough running sometimes when it is sucking in the fumes. In other words it is normal. My SS does it also.
See http://auto.howstuffworks.com/evapor...ol-system1.htm
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 08-15-2014, 01:37 PM   #14
Swacer
Drives: 2018 GT350
Off to the Dark Side
Swacer is offline   Reply With Quote
