Old 08-19-2014, 09:09 PM   #1
Zlay93
Drives: 2013 TwinTurbo 2SS
Hoosier Drag Radials
I have a few questions about a set of drag radials, and skinnies before i decide to buy them. The front tires are 26" x 6" x 17" Mickey Thompson Sportsman S/R. The speed rating for the tires H. Which is up to 130mph. Is anyone running these tires or can anyone give me information on why its only rated for 130mph. The rear tires are 275/40/17 Hoosier DOT Drag Radials. I was reading online about them, people are saying to only use them at the track and that they are not to be driven on. Is anyone running these tires on the street?
Zlay93 is offline   Reply With Quote
Old 08-19-2014, 10:07 PM   #2
jrpxxii
jrpxxii's Avatar
I have run drag radials on the street with no problems
Old 08-20-2014, 05:41 AM   #3
Zlay93
What tires do you run? I guess the hoosiers are bad on the street?
Old 08-20-2014, 05:42 PM   #4
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
I think with the hoosiers would be fine in dry weather.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 08-20-2014, 05:52 PM   #5
Zlay93
Okay, I'm more worried about the skinnies. Why would they only be a H rating up to 130mph?
Old 08-22-2014, 11:05 AM   #6
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I have a set of hoosier drag radials. They are basically a slick with two groves cut all the way around the tire to get a DOT approval. If it is dry they are fine, if you hit any water at all they hydroplane. They are a very focused drag tire. I just mount drag radials when going drag racing. You could drive on them in the dry. I personally think you are better off buying another tire to mount for street driving.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
drag radials, hoosier, mickey thompson, skinnies
