High Angle Hell
Drives: 2014 2SS 1LE Join Date: Mar 2014
Exhaust upgrade
ok guys need your help. I'm looking to upgrade my exhaust and I'm stuck on which system to go with. I have three in mind. 1) go with the NPP exhaust 2) go with borla ATAK cat back or 3) SW sideburner exhaust. I like the sound of the NPP and the Borla but I also like the idea of the sideburner. The only thing about the sideburner is that it is not its own exhaust system it adds on to your existing system. Let me know what you guys think.
Brothers don't always have the same mother Always remembered, Never forgotten |
PaPa Smurf
Drives: 2022 SS 1LE Join Date: Jul 2014
Skip the cat back and get LT's and high flows.
2022 Rapid Blue SS 1LE
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
I guess it depends on your future goals. If you AT ALL plan on getting LT headers, then skip the cat back for now, as stated above.
The NPP is not really that attractive of an option if not installed with factory functionality, so at this point I would skip that option too. As far as Borla goes, I dont think their systems are worth the money as there are better sounding systems that do a FAR better job of cutting down drone than Borla does. If you have your heart set on a cat-back then the only one I will suggest is the SW Retro Chambered Cat Back. Good luck!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
No Tags/Habitual Violator
Drives: 6.2 Z71 Join Date: Sep 2011
IMO - NPP is fine without factory controller on a Camaro. I have done it before and would again. A lot of owners pull the fuse on the controller anyway.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
If you are going to spend money on an exhaust system, I would make sure that it would lead to a significant improvement in performance, not one that just sounded better or is just louder than stock (even if it meant a tune). If there was not a significant performance gain, I might hold onto my money....just my $.02.
#6 |
![]() Drives: 2014 Camaro 2SS RS 1LE Join Date: Jul 2014
If you're going for sound, stainless works retro chambered is amazing. If you're looking for performance, get LT's and high flow cats. If you're looking for both, do all of the above with time management and priority in mind.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Apr 2014
I would recommend the Borla system
I carry their products and their good. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘13 1LE Join Date: Jul 2013
With fuse out, NPP is essentially a straight pipe.
Luv it
#9 |
![]() Drives: 2014 Chevy Camaro SS w/1le Package Join Date: Mar 2014
I've been super happy with the Borla S-Type for a few reasons. Sound is good without much high RPM drone, it's much lighter than the stock system, and the HP gain is pretty good.
On the down side, the tips poke out a bit further than I'd like and because of the way the rear bumper is shaped, it creates an optical illusion that the tips are pointing down, but they're not. Plus, you can get the s-type on amazon for a very reasonable rate
DFTBA!
2014 Camaro 1SS w/1LE Track Pack |
#10 | |
#11 |
![]() Drives: 2021 Camaro 1SS 1LE Join Date: Aug 2014
I came from the Mustang world and had multiple exhausts on multiple ponies.
None sounded or looked better than the NPP does on these cars with the fuse pulled, IMO. I can't imagine paying for anything different. The dual tips look great, the exhaust has zero drone, it has a low bass rumble with no rasp, and it is the perfect volume at all RPMs (gets attention while not being too loud). Since it is best with the fuse pulled anyway, you don't have to worry about whether it came factory. And, I couldn't care less about the weight. And anyone who claims HP gain with just a catback is full of the proverbial feces. Just my $.02 |
#12 | |
+1 on everything above!!
#13 | |
#14 |
What kind of sound are you looking for? As others have said, set of headers will really wake up the stock exhaust, so that may be the ticket where you can get the sound you are looking for AND performance. If you will not be doing headers for a while, keep in mind when choosing your exhaust system that the sound will increase by a lot when headers are introduced, and some regret their exhaust decision.
That being said, I am a BIG fan of the Stainless works Retro Chambered cat-back. Feel free to call, PM or email me anytime with questions. Best regards, Tyler 888-308-6007 |
