Old 08-20-2014, 08:44 PM   #1
yab14
yab14's Avatar
Drives: camaro 14 1LTrs
break in period for mufflers
is that a myth and if not how long do they take to break in? and what is actually happening with them
yab14 is offline   Reply With Quote
Old 08-20-2014, 08:46 PM   #2
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
The systems we have installed have had a "break in" of sorts.
not really what ppl think it is.
But more of it needs to be used to burn off the inside and the oils that are inside of them.
takes a few days at most.
Youll smell something metallic burning thats normal.
Need4speed_motorsports is offline   Reply With Quote
Old 08-20-2014, 08:52 PM   #3
yab14
yab14's Avatar
thanks for the info. so people that think there breaking in they're muffler 1000 miles later are just imagining it.I read some posts about that and didn't know what they meant by it.
Old 08-20-2014, 09:54 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Between 500-1000 miles....
Mods:
Old 08-20-2014, 11:10 PM   #5
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
The break in depends on the mufflers themselves. It is very much real, though more so for some than others. Typically associates with the exhaust getting louder.
DSX_Camaro is offline   Reply With Quote
Old 08-20-2014, 11:23 PM   #6
wally mayfield
wally mayfield's Avatar
Drives: 2013 2SS 6M
just make sure the muffler bearing it's self doesn't get too hot and you'll be ok..
jc whitney makes a gauge that bolts to the top of the dash to tell you the temp.
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
wally mayfield is offline   Reply With Quote
Old 08-21-2014, 06:04 AM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
the sound of your new exhaust will change as the pipe "seasons"... basically it's a build up of carbon on the piping.. the carbon helps mellow out the sound a bit and can make your exhaust tone a bit deeper..
scrming is offline   Reply With Quote
Old 08-21-2014, 09:38 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Mods:
Old 08-21-2014, 12:08 PM   #9
wally mayfield
Drives: 2013 2SS 6M
