![]() Drives: 2011 RED Camaro Join Date: Sep 2011
FS: 2010-2011 Vitesse billet Paddle shifters *SOLD
I'm selling paddle shifters off my Camaro because im trading In my car. New condition and made from billet aluminum. Made by Vitesse. I loved the way they looked and the fit was perfect.
$65 shipped obo After so much time developing , redesigning, trying different shapes... The Paddles made the car more fun to drive, easier to reach the Paddles than those hidden buttons especially when making turns... The paddles fit perfectly the existing mechanism and require almost the same pressure to activate as existing buttons. The Paddles position allows you to hold the steering wheel without interfering with the Paddles when cruising or not needing to Down or Up-shift. They are at the same time very easy to reach when needed. Installation Instructions: 1 - With a small flat screw driver, insert it between the existing buttons and the plastic housing, pry-up and pop-out the existing buttons. 2 - Holding the Paddles upright, insert the Top pin inside the housing and using the same flat screw driver, insert it between the housing and right next to the Paddle Shifter's bottom pin by pushing away the plastic housing to allow it to enter easily without scratching or damaging the plastic. 3 - Try activating the Paddle Shifters to make sure they are well positioned and engage the shifts. 4 - Repeat the same process above on the Right hand side and you're all set Sent from my iPhone using Tapatalk ![]()
![]() ![]() ![]() Sent from my iPhone using Tapatalk
Still forsale.. Make offer on them if your interested.
![]() Drives: 2013 Blue Ray Camaro Join Date: Jun 2014
What year did these come off of?
Let's go Rangers!
from the looks of the steering wheel I'd say a 10-11.
#6 |
#7 |
![]() Drives: 2010 Camaro 2SS Join Date: May 2012
PM sent
#8 |
Sold***
