Old 08-27-2014, 05:34 PM   #1
Hera SS
Hera SS's Avatar
Drives: 2010 Camaro 1SS/RS
Unhappy Loud sounds when turning steering wheel
Any opinions on this, it's only when I turn the steering wheel almost fully. Haven't heard it during shArp turns or moving forward. I can't tell where the sound is coming from. Thanks.
Hera SS is offline   Reply With Quote
Old 08-27-2014, 06:11 PM   #2
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Sounds like something is binding up, upper or lower ball joint? I'd get it checked out before something breaks, if you have a set of Rhino ramps you may be able to figure where the problem is. Keep us informed and good luck.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 08-27-2014, 06:17 PM   #3
Hera SS
Hera SS's Avatar
That's what I was thinking but the sound is coming from the center front portion of the vehicle not near the wheels. Could it be the steering rack?
Old 08-27-2014, 06:20 PM   #4
Hera SS
Hera SS's Avatar
Would I be covered under warranty since the car is tuned? Even though the tune is not a direct cause of this?
Edit: I just realized this portion of the warranty was up a long while back.
Old 08-28-2014, 12:33 PM   #5
Hera SS
Hera SS's Avatar
Anybody have something similar?.
Old 08-28-2014, 05:52 PM   #6
Hera SS
Hera SS's Avatar
So I lifted the car and had suspension unloaded and no sound I rocked the tires by hand left and right and no wound. It only does it when the suspension is loaded and steering wheel is turned.
Old 08-29-2014, 10:24 AM   #7
Deanwr
Drives: 2013 Camaro 2SS
Noise
Possible top. strut mount bearing
Deanwr is offline   Reply With Quote
Old 08-29-2014, 11:18 AM   #8
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
I'm sure you meant bushing.
RobertRS is offline   Reply With Quote
Old 08-30-2014, 01:24 PM   #9
Wilsonation
Wilsonation's Avatar
Drives: 2014 ZL1 Vert
Front struts have bearings... Everything that turns has bearings. And the struts turn when you turn the wheel.
2014 1SS 1LE:
10/9/13 Ordered
10/16/13 Queued
10/28/13 TPW
11/2/13 Built and Bayed
11/7/13 Shipped
11/14/13 Brought home!
Wilsonation is offline   Reply With Quote
Old 08-31-2014, 07:30 PM   #10
Hera SS
Hera SS's Avatar
Exclamation
Still haven't figured it out but I think that might be the area it's coming from.
Old 09-01-2014, 09:38 AM   #11
1Kingty4lifeSS
Drives: Black ls3 2011
I have the same issue when the car is cold and I turn left or right its a uneasy noise I believe coming from the front of the car
1Kingty4lifeSS is offline   Reply With Quote
Old 09-01-2014, 10:47 AM   #12
bonesrn27
Drives: 2010 Camaro SS
I could also check the sway bar endlinks to make sure they are snug and not "jumping" at the upper and lower attachment points when turning wheel;may explain the difference when loaded and not,my 2 cents,good luck
bonesrn27 is offline   Reply With Quote
