Old 08-31-2014, 06:18 PM   #1
VINNY1980
VINNY1980's Avatar
Drives: 2010 camaro 2ss abm m6 , 2013 zl1
Send a message via AIM to VINNY1980
Tuned
Bought my ss with cai headers and exhaust done already. But things didnt feel just right to me . So then i meet phil from tampa tuning on here. We discussed some thing and i made appointment to go see him. He took car for drive and then right onto dyno. First pull blow black smoke out exhaust and he notice knock sensors were are messed jp in the programming. And it was running really really rich. So after couple hour of his magic it ended up at 420 hp and 406 flbs of torque. And the car is a different car. And now enhine is safer because he got knock sensors working like they should. Also tuned out the decel pop for me .
I would recommend anybody who is wanting a tune or thinking about a tune to message him in here or give him a call you wont be disappointed.
Thanks again phil at tampa tuning you made car fun to drive again.
Your friend tom
VINNY1980 is offline   Reply With Quote
Old 08-31-2014, 06:38 PM   #2
raptor5244
Drives: 2022 CT4-V Blackwing
Nice. Did Phil notice if the car was tuned previously? Was it just tuned incorrectly or not tuned at all? Usually cai and headers won't run badly unless on stock tune, it will just throw a CEL from not having the o2 sensors tuned out. Sounds like the previous tuner didn't know what they were doing.
raptor5244 is offline   Reply With Quote
Old 08-31-2014, 07:09 PM   #3
Tenring
Tenring's Avatar
Drives: 2015 SS/RS M6 Commemorative
I like the decel pop!
Tenring is offline   Reply With Quote
Old 08-31-2014, 08:00 PM   #4
VINNY1980
VINNY1980's Avatar
Yea it was tuned incorreclty or a piss poor tune
Old 09-01-2014, 02:13 PM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
So hoping to save vinny1980 a buck, I told him I didn't want to pull the tune off the car first because it would clear codes and can reset the computer and the fuel trims. So when he arrived, per our discussion, I intended to sell him a Vmax ported throttle. I remove his air intake tube, and see his throttle body is already ported, but it looked like hand ported. No sense throwing a Vmax on it because it looked like a Vmax with additional hand sanding. I didn't remove the throttle body to see if it had a Vmax serial number, because I really didn't think that was the problem.
I said let me take it for a 5 minute ride just to get a scan before I pull the tune off. I scoot up to the traffic light and back, and review the scan. Im seeing the fuel trims were adding 5-6% fuel. Not looking at the tune yet, I said lets put it on the dyno and see how it pulls.
I strap it down, get the fans on it, do a base line, and this is what I see. 8* of knock and AFR of 10.70
I noticed how fast it was trying to clear the knock during the scan, and how rich it was. I told Vinny that I was going to find the tune loaded up on fuel and timing, with numbed up knock sensors. I could already tell who tuned the car based on what it was doing.
It this point I pulled the tune off the car, reverted a lot of it back to stock, and loaded my baseline to start working on it.
A couple hours later, it was a very good tune with the safety features back active in the car.
Tampa Tuning is offline   Reply With Quote
Old 09-01-2014, 02:31 PM   #6
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
Makes you wonder who did the original tune.
Ohten is offline   Reply With Quote
Old 09-01-2014, 03:06 PM   #7
jc615
jc615's Avatar
Drives: Camaro and Sierra
Wow, that sounds horrible. From knock sensors being numbed pretty sure that tells everyone who it is
jc615 is offline   Reply With Quote
Old 09-01-2014, 03:29 PM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
well who was it?
can we find out with out this thread getting locked?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-01-2014, 06:19 PM   #9
white ZL1
Drives: none
Spill it.
white ZL1 is offline   Reply With Quote
Old 09-01-2014, 09:17 PM   #10
Wilsonation
Wilsonation's Avatar
Drives: 2014 ZL1 Vert
Originally Posted by white ZL1 View Post
Spill it.
X2 so I can stay away...
2014 1SS 1LE:
10/9/13 Ordered
10/16/13 Queued
10/28/13 TPW
11/2/13 Built and Bayed
11/7/13 Shipped
11/14/13 Brought home!
Wilsonation is offline   Reply With Quote
Old 09-10-2014, 04:24 PM   #11
thesaint
Drives: 2011 camaro ss/rs
X3
thesaint is offline   Reply With Quote
Old 09-11-2014, 09:23 AM   #12
ytown87
ytown87's Avatar
Drives: C6 Corvette
how i wish i knew what all those colorful lines meant
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 09-28-2014, 05:09 PM   #13
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Folks like Phil knows EVERYTHING about those colorful lines and whether they are in the "good" range or the "bad" range. After making that determination, folks like Phil can adjust it to the "good" reading PROPERLY.
I like posts where folks say Phil sends them "tweaks" to get an already tuned car dialed in to Phil's (and surely the customer's) satisfaction.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 09-29-2014, 11:36 AM   #14
Hotwheels426
Hotwheels426's Avatar
Drives: 2013 2ss hot wheels camaro vert
drove 6 hours to have phil tune mine..did a great job..he is one of the best..
SLP SUPERCHARGER,3.6 PULLEY..HEADERS,HIGH FLOW CATS,BORLA S CATBACK,CAI INTAKE,ZL1 FUEL PUMP,ELITE CATCH CAN,TUNED BY PHIL AT TAMPA TUNING
Hotwheels426 is offline   Reply With Quote
