Old 09-01-2014, 11:35 AM   #1
191185
Drives: 2010 2LT/RS 6A
How to remove wire harness for headlight bulb ?
Hello,
2010 camaro RS headlight bulb, I can get the bulb out, but I could not get the wire harness off .
This is the RS, so it has the factory HIDs
Are you supposed to pry up the tabs on all four sides ?
Do you remove the harness then the bulb, do you just pull really hard ?
I took the bulb out first, then tried the harness, couldn't get it off, and didn't want to break anything
191185 is offline   Reply With Quote
Old 09-01-2014, 12:35 PM   #2
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
wiggle it side to side while pulling down
mycamaro2011 is offline   Reply With Quote
Old 09-01-2014, 01:52 PM   #3
191185
I just pulled and wiggled and it worked. I was worried about having to press a clip in or breaking off a clip or something
Old 09-01-2014, 01:54 PM   #4
191185
I have the bulb and ballast out, it's all one piece. Can I buy a new bulb and ballast together ?
Amazon only shows non hids
Manual says H13 which appears to be the regular non RS bulb
Anyone know what part number for the headlight bulb, with the ballast ?
Old 09-01-2014, 02:26 PM   #5
191185
Alright, I just ordered a bulb from Camaro5DIY.com , I should be good to go. Do they offer discounts to forum members ?
Old 08-14-2015, 06:49 PM   #6
RingLeaderMan
Drives: 2014 Camaro 1LT Rs
I have a 2014 RS and I cannot seem to remove mine from the drivers side. I wiggled and pulled but it just will not come out. Do i have to press something in or do I just pull it from the wire? I don't want to break anything.
RingLeaderMan is offline   Reply With Quote
