Old 09-01-2014, 01:10 PM   #1
hitman55
Drives: 1994 camaro v6
1994 camaro high idle
I have a 1994 Camaro v6 . when I go to crank it up it idle normal but then it goes up to 2100 rpm. any ides what might be causing it to idle so high ?
hitman55 is offline   Reply With Quote
Old 09-01-2014, 01:12 PM   #2
PCbuilder1997
Drives: 1996 Chevrolet Camaro RS Coupe
are all of your auxilary things off? (A/C, Heat, lights, etc.)
PCbuilder1997 is offline   Reply With Quote
Old 09-01-2014, 01:28 PM   #3
hitman55
yes I have all of it off
Old 09-01-2014, 05:32 PM   #4
PCbuilder1997
What are you temps? like are you running too hot? or is everything in range of normality?
Old 09-02-2014, 01:10 PM   #5
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Have you tried a forum better suited for non-5th gen cars?
I'd recommend ls1tech.com
2016 Camaro HBM A8, 2SS, NPP, Sunroof, Kalahari Interior/kneepads, Black bowties, 56v:
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
-Oracle ghosted LED sidemarkers
Adrian97c is offline   Reply With Quote
Old 09-02-2014, 03:50 PM   #6
Corp Z
Drives: Camaro
Have you checked for codes stored in the PCM? It could be alot of things. Is the throttle cable sticking or not opening smoothly? Is the throttle body dirty? THe throttle position sensor may be pooched or the IAC motor or both. Its a 20 year old car so lots of things to check.
Corp Z is offline   Reply With Quote
Old 09-03-2014, 08:49 PM   #7
hitman55
everything is normality
Old 09-04-2014, 04:47 PM   #8
Bradley
Gray Eagle
Bradley's Avatar
Drives: 2010 Camaro 2SS/RS IBM, 1994 Camaro
There might be a vaccuum hose disconnected. My 3.4 has done the same thing in the past. Once I found it and reconnected it the idle was back to normal.
Ordered - 14 Aug 2009 Born - 4 Nov 2009 Delivered - 17 Dec 2009
Bradley is offline   Reply With Quote
