Old 09-01-2014, 06:20 PM   #1
13ZL1
Drives: 2013 ZL1 Convertible
How hard is it to install injectors ?
Thinking about installing id 850's myself. What is involved, and how long does it take ??
13ZL1 is offline   Reply With Quote
Old 09-01-2014, 07:11 PM   #2
white ZL1
Drives: none
Pretty easy.
Relieve the pressure in the rails, then there's a few bolts holding them down. 1 hour job taking your time I'd say.
Just remember to lube up the o-rings before you slide the injectors into the rail or the manifold.
white ZL1 is offline   Reply With Quote
Old 09-01-2014, 07:13 PM   #3
JackalopeZL1
JackalopeZL1's Avatar
Drives: 2013 ZL1
Don't you needs to change the tune with new injectors?
2013 Silver ZL1
JackalopeZL1 is offline   Reply With Quote
Old 09-01-2014, 07:17 PM   #4
13ZL1
That is coming when I change pulley.
Old 09-01-2014, 07:20 PM   #5
white ZL1
Drives: none
I'm trying to find the little write up that someone else did, but searching on my phone is kinda jacked up.
Edit: got it. http://www.camaro5.com/forums/showth...or#post6048915
Old 09-01-2014, 07:38 PM   #6
13ZL1
Thanks ! Sounds like it could be a PITA ...
Old 09-01-2014, 07:46 PM   #7
white ZL1
Drives: none
Not at all.
Old 09-01-2014, 11:03 PM   #8
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Just pull your fuel pump fuse or relay and let the car idle and die. Then un-bolt the rail and install new injectors. Not hard at all.
2013 ZL1 #7860 is offline   Reply With Quote
Old 09-02-2014, 11:12 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
This what you're looking for?
http://www.camaro5.com/forums/showthread.php?t=283272
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-02-2014, 11:18 PM   #10
white ZL1
Drives: none
Even better.
Good catch on the data too.
