09-02-2014, 12:21 PM | #1 |
Drives: ZL1 Join Date: Jan 2014
Adding 8 amp component.
Where is a good place to get an 8 amp switched supply. I'd like to get power only when the key is on.
09-02-2014, 01:05 PM | #2 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
Aux power outlet in the console....
09-02-2014, 08:54 PM | #3 |
09-03-2014, 09:20 PM | #4 |
So is there a good spot in the fuse box? I know it seems like a simple question but I don't know what loads are already on the various buses.
09-03-2014, 09:34 PM | #5 |
Drives: '12 2SS/RS 45th vert, '14 2SS/RS Join Date: Nov 2013
Pick a circuit that meets your needs in the fuse box (i.e. constant, switched, etc) and use an Add-a-Fuse.
2012 2SS/RS LS3/M6 - C.A.I., Nightshade Tail Lights, ZL1 Fascia and Rockers, NightOwl Halo and Grille LED System, Bravado Americana Wheels With NT05 Rubber.
09-04-2014, 12:04 PM | #6 |
If you can tell us what you are trying to install, it would help locate where you would tap into the fusebox.
09-04-2014, 04:11 PM | #7 |
