Old 09-02-2014, 04:37 PM   #1
Richmaro_13
Richmaro_13's Avatar
Drives: Chevrolet Camaro V6
Post MY DOME LIGHT IS NOT TURNING ON PLEASE HELP!!
Hello I have a 2013 Chevrolet Camaro v6 and I have a problem and don't know what else to do to solve the issue. About 3 months ago I installed two LED strips, one on driver foot well and second on passenger foot well I hooked them both up to a wire under the steering column ( the wire I hooked them up to is the power supply to the dome light). The installation was a success then about two or three months past by no problem at all everything was working perfectly then all of a sudden the strips stopped working and also my dome light stopped working. What do any of you all think it was a fuse? maybe the wire went bad? any suggestions please reply I need to get the dome light working again its really annoying not to have it working. Thank you
Richmaro_13 is offline   Reply With Quote
Old 09-02-2014, 04:39 PM   #2
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
Check your ground wires.
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
Old 09-02-2014, 06:09 PM   #3
Richmaro_13
@pickwithaustin Thank you for taking your time on replying to this post. Question where Can I find the ground cables?
Old 09-02-2014, 10:32 PM   #4
pickwithaustin
I just installed the same this last weekend - see photo (black interior, I put in two strips of red LED's in the foot well). They run on two wires, a positive and a negative. The positive is your power and the negative is your ground. Where did you hook up your ground? That is the wire I am referring to.
Old 09-02-2014, 10:54 PM   #5
Richmaro_13
@pickwithaustin I had it the same way as you have it there on the pic. the red one (+) I hooked that one up to a wire where the steering column is like really deep inside that's where it is located and then I got ground from where the shift is you just pop open the plastic panel on the driver side where the center column is.
Old 09-02-2014, 11:51 PM   #6
DandDC09
DandDC09's Avatar
Drives: '10 2LT/RS, '13 Malibu
Sounds like it isn't lighting up!
DandDC09 is offline   Reply With Quote
Old 09-03-2014, 09:37 AM   #7
pickwithaustin
I did not tie into the dome light - I have mine on it's own independent circuit with a on/off switch installed below my radio console. I tied in to the aux power (which feeds what used to be called the cigarette lighter). I wanted to be able to control the foot well lighting without the dome light.
dome light, electrical short, fuse, wiring
