09-02-2014, 04:52 PM | #1 |
Engine temp and fan?
I was detailing my car and let the car idle to dry up some moisture on the exhaust and engine compartment. I never noticed this but the fan never kicked on. At what temperature does it start to turn on?
Also what temperature range do your cars run while just cruising around mine is like 192 driving normally. Gets over 205 when idling at at stop for awhile then when moving drops back to 192. Just curious and a little bit paranoid.
Laus Deo
09-02-2014, 05:41 PM | #2 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Somewhere between 212 and 215 I think..
09-02-2014, 09:36 PM | #3 |
Drives: 2013 Black ZL1 "Auto" Join Date: Aug 2014
I put in the 160 thermo
Cruising at 80 mph @ 175 Stop n go Traffic @ 188 on a 100 degree day Running hard on back roads @196 That is going off the gauge display |
09-02-2014, 09:53 PM | #4 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
They start at 214 deg. Full speed fans at 228 deg
Bryan 2018 ZL1 M6
09-02-2014, 09:55 PM | #5 |
Drives: '14 1le Join Date: Jan 2014
The ls engines run cooler by design. The fan would have come on sooner if you had the Ac on.
09-02-2014, 10:05 PM | #6 |
Banned
Drives: 2013 CRT ZL1 Join Date: Sep 2012
Your temps are totally normal. If anything there lower then most. My car runs between 185-210 as a norm but I've seen it as high as 225 ....
I may try the 160 t-stat like that other guy though, seems like his car runs a lot cooler then mine in all his conditions he listed. He listed he runs 196 when whaling on it, if I'm whaling on mine I'm definitely running 200-220 |
09-03-2014, 12:37 PM | #7 |
thanks for the replies gents. I am going to get the 160 stat as well.
Laus Deo
09-06-2014, 03:10 PM | #8 |
Bens1LE
Drives: 2014 ss 1LE Join Date: Apr 2014
09-06-2014, 04:28 PM | #9 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
