Reminder to Check Spoiler
I have 1700 miles on her and was washing her today. The 2 bolts on the drivers side of the spoiler were loose. Took 2 seconds to tighten up. Just a reminder to check it.
Cyber Gray/Black/Black Stripes,2SS/RS,Auto
1100, Preliminary order accepted 10/16/09 3800, Order produced 6/22 Vin:2G1FK1EJ9A9120942 6000, Delivered to the customer 7/7/09 |
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
Scott "Fbodfather" said the falty torque wrench was replaced that was causing the issue. However this issue may still be occurring on newer VIN numbers.. Yours is 20942 and mine is 22517 and still had them loose.. So it is hard to tell when the problem was fixed..
Bought my Camaro from Eric Hall(817) 421-7266
2017 SS
I have the same exact problem. Not sure if I should fix it or take it to the dealer?
![]() Drives: 2011 CTS CPE & 2010 2LT/RS CGM Join Date: Jun 2009
Replace the existing nuts with nylon locknuts and save yourself some future problems.
Yea, just fix it. It takes 2 minutes and avoids the hassle if you have to leave the car.
#6 |
![]() Drives: 2010 Camaro Join Date: Jul 2009
I found the same issue with my spoiler; all four nuts were loose, and I can hear a fith nut when I open and close the trunck.
I used permatex thread sealant/locker, hope this fixes the problem. If this does not fix the problem, I'll demand Chevrolet to replace them with nylon lock nuts. I hope Chevrolet reads this thread, otherwise they will not change anything in thier manufacturing/assembly process. |
#7 |
![]() Drives: 2010 RJT 2SS/RS, 2001 Ford Focus Join Date: Jul 2007
Had the same thing on the drivers side. Noticed it was loose last time I washed it, figured I would have the dealer fix when I bring her in for a new bevel and sill plates. Unfortunately too late,..opened the trunk and heard one of the nuts ratteling inside. Easy fix to tighten yourself, now I just got to get the other one out.
#8 |
![]() Drives: 2014 2SS/RS/NPP Red Hot Join Date: Jun 2009
To do it correctly, it will take a little bit longer than 2 minutes. There are 4 easily accessible bolts under plastic covers. However, there are two more bolts under the felt trunklid cover which requires the removal of several plastic pieces. They require a large flat fork or other utensil to pry out. I had a total of 3 bolts come off and fall into the trunk (two from the center under the cover, and one on the driver's side). Using nylon locknuts eliminates the problem.
#9 |
![]() Drives: rumble bee,2SS 6sp Join Date: May 2009
same problem here and im in the 24xxx vins.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
#10 |
![]() Drives: 2SS, 48 Plymouth, 77 Coup Deville Join Date: Nov 2008
There are 6 nuts
#11 |
![]() Drives: 2SS IBM m6 / 04 Nissan Titan Join Date: Dec 2008
just tightened mine last week...Vin 10942
2010 IBM 2SS 6M
SLP LoudMouth II Axle back kit CAI intake bought at C-Fest From Jannetty Racing ![]() |
#12 |
Thank you Oshawa/St.Cats!
Drives: was 2010 2LT RS 2G1FC1EV4A9103434 Join Date: May 2009
This is the thread that first raised the spoiler bolt/nut issue that I recall http://www.camaro5.com/forums/showthread.php?t=29678. I didn't heed the warning and have one sliding up & down my trunk lid when opening/closing - I know the dealer service will fish it out - annoying in the meantime.
Check the rest of that thread for the discussion on changing the nuts to nylok fasteners.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
#13 |
![]() Drives: 2010 SS Silver w/Black Stripes Join Date: Jul 2009
YEP....I didn't heed the warnings and sure enough this weekend I noticed that lovely sound of a nut rattling around as i opened and closed the trunk....then it mysteriously stopped. I took it to the dealership this am to let them fish it out - besides I had a quarter panel not fitting flush for them look at as well.
#14 | |
Drives: 89 IROC 350 Join Date: Mar 2009
![]() DAMN... I guess I am going back outside...
| High Wing Spoiler or Not? | RSm1thX | Cosmetics and Lighting Modification Discussions | 109 | 04-03-2013 06:36 PM |
| No spoiler option on v6 models ... ? (Build your own Camaro) | TicoSloot | Cosmetics and Lighting Modification Discussions | 17 | 04-22-2010 06:51 AM |
| Request for spoiler mount pictures | KK2010SS | Camaro Photos | Spyshots | Video | Media Gallery | 2 | 05-27-2009 11:35 AM |
| Sin Spoiler? | Valentino562 | Camaro Photos | Spyshots | Video | Media Gallery | 16 | 05-15-2009 09:16 PM |
| Blade Spoiler? | CoolestCamaro873 | Cosmetics and Lighting Modification Discussions | 36 | 05-14-2009 06:45 PM |
