09-03-2014, 10:34 AM | #1 |
Drives: 2010 2SS Join Date: Jun 2009
Looking to buy new rotors
I am looking to buy new rotors for a 2010 Camaro SS, but there are too many options!
Does anyone know the difference between lets say Brembo Sport Slotted, Stillen Slotted or Stoptech Slotted rotors? Besides the price of course. I am looking for rotors that are the same weight as OEM or lighter and can handle daily driving with "spirited" moments. I probably won't be tracking anytime soon. Any reviews or recommendations on those above models or any other ones? |
09-03-2014, 10:46 AM | #2 |
I never really looked into details of the rotors. I always thought slotted rotors were as good as the other slotted rotors. Sure there are different weights but who cares if you are talking about an extra 30 pounds on your car. Id like to here someone chime in on this.
09-03-2014, 11:39 AM | #3 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Brake Performance:
http://brakeperformance.com/brake-ro...ake-Rotors.php affordable, lifetime warranty, and meet your DD requirements. (plus they're on sale & include free pads, although I would pay the extra $40 for their premium)
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
09-03-2014, 11:51 AM | #4 |
Too much is never enough!
I went with R1 Premiere....there cross drilled and slotted...you can get them either way. but im very happy with them....I frequently heat my brakes up and no warp-age so far....thats after 9k miles anyway...talk to Chase from APEX hell set you up.
09-03-2014, 12:05 PM | #5 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Look at DBA 4000's.
I know you said you don't track but if if they can handle the abuse of the track then the street should be no issue and they should last even longer. Also, stay away from the drilled... they crack easier and are WAY harder to clean, imagine sticking something in each hole to clean EACH AND EVERY ONE OUT... PIA. Tyler @ JDP Motorsports for has a variety of rotors and DBA's. I think Maryland Speed might have them too. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
09-03-2014, 12:20 PM | #6 |
OEM Rotors are honestly a great piece. If you are looking for an upgrade, the DBA rotors are a very good option if you are looking for an upgrade and they come with a few different options.
Feel free to call, PM or email me anytime with questions. Best regards, Tyler 888-308-6007 |
09-03-2014, 12:31 PM | #7 |
2010 2SS/RS M6
Tyler, are the Granatelli dimpled/slotted rotors any good?
09-03-2014, 12:39 PM | #8 |
Drives: Varies Join Date: Dec 2009
We have a brake special going on right now!
http://www.camaro5.com/forums/showth...=257770&page=6 PM or Call me directly with any questions! Thanks JT |
09-03-2014, 01:05 PM | #9 |
Yeah, They are pretty good. From my understanding they are OEM rotors which have been dimpled and slotted with a zinc coating to prevent rust. For the most part, I'd say they'll provide more of a looks upgrade over OEM, but not too much of a performance upgrade over stock. They are not much more than OEM though.
09-03-2014, 02:30 PM | #10 | |
You are correct they will develop hairline cracks, that is after a long period of time and hard use. If your a track guy then I understand why you say stay away from them. For street applications and an occasional track run, there is nothing wrong with them. I have never actually sat down and cleaned the holes out of my rotors.
