Radio is ghostly connecting
So recently my factory radio has been connecting to my cellphone via bluetooth when the car is off. It's never done that before. I also noticed that I can turn the radio on without the key being in the ignition. Is this something that I haven't noticed before or is my radio possessed?
TSP 1 7/8" Headers, Cat Delete / Flowtech Mufflers, Vmax CNC Ported TB, SLP UD Pulley 25%, Elite Catch Can, Vararam CAI, Vararam Power Wedge, Taylor 49 Race Wires, Mishimoto Silicone Hoses, B&M Transmission Pan,
Tampa Tuning Tweaked & Tweaked again |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Unbelievable. Mine started doing this yesterday and I cannot figure it out for the life of me. It sucks, my phone was ringing all day and I would try to answer and nothing. Then I realized it was connected to Bluetooth.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
You can turn the radio on without the key. It's a feature
you can power on the radio w/o the key inserted, but it'll eventually turn off to save the battery.
I've had my car for four years and over 90,000 miles and it has never done this until yesterday. The radio eventually powers down but blue tooth stays connected unless I manually turn it off.
#6 |
Also just realized with the key removed from the ignition when you open the door the radio doesn't shut off, it always did in the past.
#7 |
![]() Drives: 2011 LT Black Join Date: Nov 2011
#8 |
Starting to piss me off. Every time the phone rings it transfers to my cay and I have to manually turn on the phone ear piece. My customers are getting annoyed as well. Got to figure this out.
#9 |
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Disable bluetooth on your phone.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#10 | |
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
#11 |
#12 |
I can certainly turn off the bluetooth, but if I forget its annoying. This never happened before, still need to figure out why it's happening.
#13 | |
Step 1: Have the bluetooth radio reset by the dealer. Step 2: No more problems. But seriously, if you have a android there are dozens of built in toggle buttons that can go right on your main screen, notification window, etc to switch Bluetooth on and off instantly. If you have SmartActions you can set it to turn on your Bluetooth every time you plug it into your charger (car), or a number of other triggers as well. |
#14 |
![]() Drives: 2014 1LS Join Date: May 2014
Maybe it's the part of the ignition switch that detects when the key has been removed. Do your doors unlock when you take out the key?
