![]() ![]() ![]() Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Louder Exhaust with Twin Turbos
Im currently enjoying the hell out of my AGP Twin Turbo set up its definitely awesome. however i really want to kick up the exhaust sound level. Can anyone chime in on what i can do. right now i have borla S type catback coming right after the turbos. The way i see it all i can really do it just delete the mufflers. is there anything else i can do besides that? Thanks!
![]() 2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
That's about it. Turbos naturally reduce sound.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
sell the exhaust and just run open downpipes after the turbos or add just cutouts if you want it to be able to be quieter sometimes
![]() ![]() ![]() Drives: All things Turbocharged Join Date: Dec 2010
I think the exaust you have is only 2.5" pipe. Change the system out to a dual 3" Magnaflow. That will do it and gain you a little free power.
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
winning! Even if you have a 3" cat back built...use the 3" magnaflow mufflers.
-John S.
#6 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Or you could go billy boat... they are very similar to no muffer but there is a can under the car if the cops look.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#7 |
![]() Drives: 2017 Summit White 2SS A8 Join Date: Oct 2013
3" zl1 corsa cat back and never look back! Best system out there hands down, best quality sound. It's expensive but you get what you pay for
Mod List: Stock (for now) |
#8 |
![]() Drives: Red Jewel Camaro SS Join Date: Mar 2014
I have the AGP kit with full 3" exhaust by Kooks. Sounds pretty good,but actually not crazy loud at all.Car was alot louders with headers and cats before we changed it to manifolds and turbo's.Can here the turbo's fairly easy at idle from the back of the car.
#9 |
Could you add a idle video?
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System. |
#10 |
![]() Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
X2 on that
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
#11 |
![]() Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
Same problem with me, I miss my headers lol I'm probably going to put cut outs like 6 inches past the turbos. Supposedly someone else did this, retuned it and gained a lot of power too but I'm more worried about the sound
#12 |
Too much is never enough!
Bump.....
I would love to hear some sound clips guys. I am installing AGP's TT kit next month and cant decide on what to buy for a 3 inch catback system. A sound clip or two would go a long way. Does anybody at AGP have a clip of the 3 inch Magnaflow system?
#13 |
I ended up getting a stainless works chambered 3 inch exhaust and i absolutely love it. Much louder than the borla stype i had and no drone at all its perfect.I will try to get some videos for you guys. I also recommend the CAI kit option i just installed that this past weekend and it sounds awesome!
#14 |
![]() Drives: 2012 Camaro Ls3 Join Date: Apr 2012
Does anyone have any videos with cutouts and turbos?
Dynatech LT headers/Hi-flow cats/Jannetty rough idle blower cam/Full BMR suspension/3" magnaflow catback 442rwhp-410rwtq
