![]() ![]() Drives: 2017 ZL1 A10 Join Date: Sep 2009
Need ported snout, 2.85 upper pulley and isolator
After 11000 miles my sc finally started to rattle. Guess it's time to pull the snout, have it ported and a 2.85 pulley pressed on. Does any vendors on this site offer a ported snout/2.85/isolator package?
2017 ZL1
A10 Redhot with stripe |
![]() Drives: 2013 Camaro ZL1 Join Date: Jun 2010
I'm curious about this also for when mine goes.
2013 Camaro ZL1 Black M6
Roto-Fab Intake, Apex Catch Can, Stainless Works 2" long tube headers with cat delete, Stainless Works 3" retro chambered catback, ATI Super Damper with 10% overdrive lower pulley, tuned by JRE. Sitting on Black MRR 228's wrapped in MT's. |
![]() Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
Your going to go thru all that only to put on a 2.85?
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
Because he's already got a 9.55 lower. |
#6 |
And what are your IAT's at the end of the track or during a 20 minute track session?
And how much timing is getting pulled with all that heat your generating? |
#7 |
You guys are funny,want to spend more time worrying about problems instead of correcting them,I don't road race my car I only go down the 1/4 a few times a year and judging by my power numbers on 93 octane I have a combo thats works sorry if you guys are still searching for yours.
#8 |
Worrying about rather than correcting? Not sure what that means but if If you cant answer my question, thats fine.
Dyno numbers really dont mean much to me, hence why mine arent in my sig. But hey, whatever makes you and your signature happy.
#9 |
I'm am happy b/c my car work the way it should,everybody on this site worries about stuff instead of figuring what will fix it,in my case I run a 9.55 lower and a 2.55 upper but shift @ 6100 to keep the blower speed @23K and down the 1/4 ( I don't launch my car very well) still ran very low 11's on street tires.
#10 |
Then educate me.
What am i worrying about that i shouldnt be because you found a way to "fix it"? Share the knowledge. That's what this board is for, right? Were the numbers in your sig at 6100? |
#11 | |
#12 | |
The only reason I'm changing the upper at all, is because the snout is off already. If I didn't have to pull it off the upper pulley would never be touched. For now I'm happy with the power and amount of boost I'm making. With the 2.85 upper installed, I'll be changing the lower back down to a 9.1.
2017 ZL1
#13 | ||
#14 |
![]() Drives: 2013 camaro zl1 Join Date: May 2014
ok, back to the intended topic...I'm curious also….does anyone sell a ported snout...
[SIGPIC]
