Old 09-08-2014, 12:51 AM   #1
BrenoAlves
Drives: 2SS/RS Camaro
Wanna swap my v6 differential to the v8
What are the parts that I need to put the 3.71 gears on my v6 camaro, from searching I believe its something like; a differential, some SS axles, new wheel bearing hubs.
But I would love if someone could confirm this for me and tell me kind of EXACTLY the pieces I need so i don't but the wrong things.
I have a 2014 1LT Camaro
BrenoAlves is offline   Reply With Quote
Old 09-08-2014, 08:20 AM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Auto or Manual? Auto will require all those parts plus the gears themselves, Manual will just need the gears.
Only thing else you will need is axle nuts.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 09-08-2014, 10:23 AM   #3
BrenoAlves
Auto. I want to know exactly the parts I need, like the names and which company makes them I am kind of bad at finding these things online
Old 09-08-2014, 10:31 AM   #4
MagnumForceGB
Gmpartsonline has all the parts, you will need to look through their catalog. I am doing a 1LE differential upgrade on my auto V6, total cost is going over $3,000.
Old 09-08-2014, 10:38 AM   #5
smokum
smokum's Avatar
Drives: 2010 2ssrs
Call ADM performance. Andy has a few new rpm built 3.91 rears in stock. Im sure he has a set of axles and possibly hubs. Im sure he would hook you up. Drive down and swap it out same day and head home again.
smokum is offline   Reply With Quote
Old 09-08-2014, 11:52 AM   #6
Merc
In The Circle
Merc's Avatar
DSS can also supply all the parts you will need. The axels will be custom to fit rear outer spline. I'll bump the thread on, cause I have already this mod for a customer.
Old 09-08-2014, 12:51 PM   #7
BrenoAlves
The thing is i'm kind of new to car part so I dont know which parts to order exactly, if anyone can help me with this that would be great. Ill give this Andy guy a call see if he can help me out.
Again the question is which parts do i need to perform this swap
Old 09-08-2014, 12:52 PM   #8
BrenoAlves
How are you doing this please let me know, parts and all, thats like exactly what I want to do to my little v6
Old 09-08-2014, 01:04 PM   #9
MagnumForceGB
Here are the part numbers:
1LE/ZL1 Hubs - 22924741 (x2)
1LE Diff (3.91) - 22806794
1LE LH Axle - 22806795
1LE RH Axle - 22806796
1LE Axle Nut - 11611234 (x2)
Go to: http://www.gmpartsdirect.com put the part #'s in.
Might be worth seeing what other shops can do it for, might be cheaper that way.
Old 09-08-2014, 01:53 PM   #10
BrenoAlves
Man you don't know how much you just helped me. Thank you good sir. I've read online that I might or might not need an SS driveshaft, I didn't see that in the list you gave me. Will I need one or not?
Old 09-08-2014, 02:02 PM   #11
Merc
In The Circle
Merc's Avatar
You will need a driveshaft, I don't believe your stock driveshaft will work.
Old 09-08-2014, 02:09 PM   #12
BrenoAlves
Ok thats not bad, do you happen to know which one I will need exactly and the part number
Old 09-08-2014, 02:11 PM   #13
Merc
In The Circle
Merc's Avatar
Call Frank at the Driveshaft Shop and let hime know what you doing and he will build you the correct shaft. Tell him Merc sent.
Old 09-08-2014, 02:11 PM   #14
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Yes, you need the rear half of an SS drive shaft as well.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
