Old 09-08-2014, 09:08 AM   #1
RoachDad
Drives: 2010 Camaro SS/RS
Resonator for Kooks
I have Kooks headers and full exhaust. I have a drone around 1500-2000 RPM which is 70 MPH in 6th gear so it a problem.
I have heard that a resonator will solve it but I've also heard that the Kooks Resonator will not fit since there isn't a straight pipe long enough on the Camaro.
Has anyone used a resonator from a different brand on a 5th Gen Camaro?
thanks. Kooks has awesome sound and performance. if I can make that drone a little better they will be perfect.
RoachDad is offline   Reply With Quote
Old 09-08-2014, 11:47 AM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
http://www.flowmastermufflers.com/?p...15150s&x=6&y=5
This is a resonator that I am thinking of going with that might solve my problem of Drone and AFM sound. It might work for your application.
Dimitrim is offline   Reply With Quote
Old 09-08-2014, 06:56 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
3.91 gears will shift the RPM range that you sit on the freeway and also take some load off the engine which reduces drone. They're also a great upgrade; something to consider.
Best regards,
Tyler
888-308-6007
Old 09-09-2014, 02:43 PM   #4
SpeedSports
SpeedSports's Avatar
Drives: 2011 SS- Whipple SC, Kooks headers
Im agreeing with Tyler.
Best regards,
Tyler
888-308-6007
SpeedSports is offline   Reply With Quote
Old 09-09-2014, 07:02 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Kooks full exhaust is notorious for drone. I didn't know kooks made a resonator. I doubt a resonator will take care of the drone but it will most definitely reduce it some. The only way I know of to get rid of the drone, without going with a different exhaust, is to add J pipes.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
