![]() Drives: 2013 Camaro ZL1 Join Date: May 2013
How do I remove the deckoid spoiler?
How do I remove the decklid spoiler? The nuts are easy enough, but the wiring does not look so easy. Any help?
![]() Drives: 2013 ZL1 Join Date: May 2014
No experience with this but I believe the screws are hidden under the 4 plastic plugs on the under side.
![]() Drives: 13 F150 Eco 14 ZL1 650 RWHP Join Date: Sep 2013
There is no wiring... You have to remove the carpet piece somewhat to get to 2 nuts otherwise the other 4 nuts are under the rubber caps which can be removed easily......
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla Join Date: Aug 2013
How can there be no wiring with the third brake light in the spoiler?
![]() Drives: 64vette,2010 2SS,2013 Zl1 Join Date: Mar 2013
never mind the wiring, it easy after the spoiler is off, there are 4 nuts to remove from the trunk and snap connectors 1 at each end and 1 on each side of the light. once you removed the four nuts the only way to get the snaps off is to pry the spoiler up with a sturdy plastic tool, you have a 90% chance that they will break but you'll need new ones anyway, hope that helps
64. |
#6 |
Rumblebee
Drives: ZL1 Rally Yellow Join Date: Apr 2013
These snaps.
Any part number on this so i can check if my local dealer can order them? |
#7 |
Next question is why? ZL1s have beautiful spoilers.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Dec 2012
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Unfortunately Chevrolet put zero thought into the spoiler for the ZL1 vert.
#10 |
Nothing wrong with the spoiler. The decklid has a few light scratches in the clearcoat adjacent to the spoiler and they will just be easier to buff out with the spoiler off.
#11 |
![]() Drives: 2013 ZL1 manual RHD Join Date: Dec 2013
When I fitted my Carbon Fiber rear spoiler, I managed to get a pair of long needle nosed pliers onto those dopey plastic clips and un wound them.
By doing this I didn't break them ( important when you are on the other side of the planet from your nearest Chevy dealer...) Cheers
Brad Dunstan
RHD '13 M6 ZL1 |
#12 | |
Rumblebee
I have the exact same thing on my decklid, thats why i want to remove it, too. Wonder where they came from, they were in the paint when i took delivery. |
#13 |
