Old 09-08-2014, 05:58 PM   #1
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
10rscamaro build to supercharged
Hey everyone! This is going to be my build thread for the road of fixing issues with the rx supercharger. Pulled the trigger and purchased one used from a member. Thank you everyone that have been replying to my emails and all who I ask for help to get this project done.
Currently talking to a few shops on install rates, hptuning options, and planning a good time in the next month to get this kit put on the car. I will list my current mods below, as well as bring it to the track once it is running good. Im adding a few things to the car at the same time as the kit, so let the modding begin!
Current mods:
Vararam cai, obx lt's, mace intake manifold, rx iceolator, mace pletheum spacer, ported tb, trifecta tuned, mrt v2, 4.11 ss rear, ss brembo brakes.
Will be installing: rx supercharger, bmr drop springs, bmr sway bars, bmr trailing arms with bushing kits.
Thanks for your support guys!
If anyone has a good shop located in texas let me know! I am currently stationed in abilene tx, dyess afb.
Thanks!
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 09-08-2014, 06:06 PM   #2
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Good luck on the build! I'm sure there are an absolute ton of shops in Texas that you can find!
ModBargains.com is offline   Reply With Quote
Old 09-09-2014, 08:49 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
subscribed to follow the story....good luck.
Old 09-09-2014, 12:49 PM   #4
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
What part of Texas are you in?
I suggest you take a good look at the tensioner bracket (well really everything since this is an RX kit), back when I had my V6 the bracket broke on me. Lucky for me I work for an engineering company with on staff metallurgical engineer's. We designed our own bracket. Last month I was approached by someone with an RX kit that had their bracket fail too, so this seems to be a reoccurring issue. The problem was early in the manufacturing process, the pieces were cut very crudely which lead to stress risers that ultimately lead to fatigue and then critical failure.
Here are some pictures of my bracket vs the RX bracket.
I also suggest changing all critical bolts to grade 8.
BaylorCamaro is offline   Reply With Quote
Old 09-09-2014, 01:31 PM   #5
Pathogen
Pathogen's Avatar
Drives: 2014 1LS Camaro
^This is why this site rules. Instead of bashing you for buying RX, members provide constructive advice.
Nobody with a good car needs to be justified. -Flannery O'Connor
Pathogen is offline   Reply With Quote
Old 09-09-2014, 06:50 PM   #6
10RsCamaro
Slow v6
10RsCamaro's Avatar
Baylor, thanks for the heads up! Expect me to pm you once this install starts, im going to need all the help I can get.
Once the kit arrives I will know if it is an early production or the later.
Old 09-16-2014, 10:29 AM   #7
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Good luck with the install and tuning. Looking forward to some dyno results.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer
Gretchen: 1994 Ford F350 Crew Cab Long Bed 4x4
51k mile survivor
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 09-16-2014, 10:33 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well I'm interested to see you get this kit worked out.
It seems most folks with the RX kit have had nothing but troubles.
How much do you plan on investing in this kit?
If you go over 5k I'd just stick to the battle tested IPF kit.
Mods:
Old 09-16-2014, 10:59 PM   #9
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
SUPER. I don't think you'll have any issues. The early kits had some problems but the bracelets have been upgraded. You should still be able to get RX to provide support. I tried to take a lot of pictures too. The shop that installed mine was a huge help.
I've been happy over all, though I had initially planned on IPF.
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 09-19-2014, 01:37 PM   #10
10RsCamaro
Slow v6
10RsCamaro's Avatar
Just got the kit and started opening everything up. Now to find a place to get it installed/tuned!
