Old 09-09-2014, 10:58 PM   #1
MattsZL1
MattsZL1's Avatar
Drives: 2013 Black ZL1 "Auto"
Spark Plug ? ZL1 575 rwhp
I have been looking all over the forum about which spark plug to run.
I am trying to find out what would be a good one to run for my setup.
Car is 2013 ZL1 Auto at this time I am making 575 rwhp and 570 ft tq. which if I under stand correctly on the drive train loss I should be right around 700hp at the crank
I have a few more mods coming in the next month that should put me over the 600 + rwhp.
Right now I am on the stock plugs.
Just trying to see what the other ZL1 guys are using.
Thanks for the HELP!
MattsZL1 is offline   Reply With Quote
Old 09-09-2014, 10:59 PM   #2
sportyb24
Romanian Outlaw
sportyb24's Avatar
Drives: 13 ZL1 , 14 Silverado Crew Cab
I have stock and I'm at 700rwhp
[/SIGPIC]2013 Camaro ZL1 M6
sportyb24 is offline   Reply With Quote
Old 09-09-2014, 11:20 PM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
NGK TR7IX
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-10-2014, 01:09 AM   #4
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
What would it do
Sent from my iPad using Tapatalk
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 09-10-2014, 07:43 AM   #5
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
Call Lingenfelter
Kevlar382 is offline   Reply With Quote
Old 09-10-2014, 07:53 AM   #6
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
Originally Posted by ZO6 Bryan View Post
NGK TR7IX
This is correct.
CAM....ZL1 is offline   Reply With Quote
Old 09-10-2014, 08:28 AM   #7
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
NGK TR7IX
At what GAP are they set?
tnspd is offline   Reply With Quote
Old 09-10-2014, 09:15 AM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
.040"
Bryan 2018 ZL1 M6
Old 09-10-2014, 09:58 AM   #9
Cooks ZL1
Drives: 13 Camaro ZL1
I see some are using the tr7ix and some use the tr6. What is the difference I know one is a step colder but how do you know which one to use for you application?
Cooks ZL1 is offline   Reply With Quote
Old 09-10-2014, 07:42 PM   #10
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
NGK TR6 here 580rwhp 571rwtq and MSD plug wires to compliment!!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 09-10-2014, 09:09 PM   #11
ZO6 Bryan
ZO6 Bryan's Avatar
NGK TR6 is the same heat range as stock but is a cheaper plug than the Iridium TR7IX. And the 7 is colder if you are running increased boost. The OEM calls for Iridium in the cars.
Bryan 2018 ZL1 M6
Old 09-10-2014, 09:15 PM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
http://www.pcmofnc.com/index.php/blo...ere-do-i-start
Bryan 2018 ZL1 M6
Old 09-10-2014, 09:29 PM   #13
MaxxMuscle
Blanchard Performance
MaxxMuscle's Avatar
Drives: 2014 Black ZL1
Sould u also change the plug wires if u go with the Iridium TR7IX ?
MaxxMuscle is offline   Reply With Quote
Old 09-10-2014, 09:35 PM   #14
Alexzl1
Alexzl1's Avatar
Drives: 2013 zl1 A6 summit white
I've used tr7ix .We also tried autolite ar103 with good result .
'13 A6 ZL1 . JLT cold air , SW 2" longtube catted, LS3 TB, 2.55 upper+ ati balancer w 10% lower . LPE cam, ID 850, msd boost a pump . Fabco HX . Best et to date 10.86 @126mph .
Alexzl1 is offline   Reply With Quote
