09-18-2014, 08:14 AM | #1 |
Drives: 2010 2SS/RS Join Date: Apr 2013
Stabilitrak and Reduced Power
UPDATE:
It's been a while but finally the problem was fixed. I hope the following helps somebody out. I ordered the ECM for my car made by ACDelco off Amazon and installed them at my local mechanic's shop hoping it would solve the problem. It didn't. The service Stabilitrak errors still appeared. I was told the car's alignment might affect the Stabilitrak so we took it to the best alignment shop in town, and the error message was still there. I took it to another dealership and asked them to run a diagnosis. This is what they found: There was a communication problem between the ECM and the ABS module, the most probable cause of which was a short circuit in the wiring. And as predicted, and one week and a half later, the damaged wiring was replaced, and the car runs like brand new. My car is now running stronger than ever and no service stabilitrak errors nor check engine problems occur. If you are in Lebanon, make sure to check Monza Cars in Beirut for the best service for Camaros in Lebanon. Hope this helps someone else out! ------------------------------------------------------------------------ Fellow Camaro owners, After a search I feel the need to start a new thread and ask you guys about a problem that has been happening to me, perhaps someone knows the solution. When in first gear and under heavy acceleration, my dash will flash service stabilitrak and won't allow me to switch to 2nd gear (I have an auto) even if I press the upshift button. It will take the RPM up to redline and then back. After that I can change to second gear but the stabilitrak icon stays light up and the car feels as if there is no traction. When I simply turn it off and back on again, the error disappears and the car goes back to normal unless I repeat the above process. When negotiating a curve, a slight increase in power making the tail kick out makes all of the lights in my dash light-up and the center console displays reduced engine power and the car shuts down. I cannot turn the car back on. I have to wait for about 10 minutes until I can start the car back on, but with the check engine light on. I insert my OBD scanner and error P0606 appears. After research, P0606 concerns the car's ECM. I talked to my local mechanic and he said that there is nothing related to the ECM. He inserted his MDI and mentioned the ABS had flashed 5 times. I have also read online it could be related to the throttle body? Mods to my car are Roto-Fab cold air intake, no cats, magnaflow muffler and an IPF tune. The car sits 1.4" lower with BMR drop springs and Hankook Ventus tires. Any help would be greatly appreciated
09-18-2014, 08:25 AM | #2 |
Res Ipsa Loquitur
Drives: 2013 Camaro SS Vert Supercharged Join Date: Sep 2012
Did you read this thread? If not, it seems to suggest that you need to have the ECM replaced. Good luck
http://www.camaro5.com/forums/showthread.php?t=318621
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
09-18-2014, 08:37 AM | #3 | |
09-18-2014, 08:46 AM | #4 |
Res Ipsa Loquitur
I believe he said that they replaced his ECM, see post #5.
09-18-2014, 08:52 AM | #5 |
Just checked you're right. I wonder why my mechanic said there is no need to replace the ECM. I'll try checking with someone else.
09-18-2014, 09:03 AM | #6 | |
www.jannettyracing.com
09-18-2014, 04:25 PM | #7 |
Go NY Giants & NY Rangers
Drives: 2013 ZL1 M6 Join Date: Nov 2013
Seems like everyone that has this problem has put a CAI in. No?
How long does it take for them to replace the ECU?
Molon Labe!
09-20-2014, 07:58 PM | #8 | |
Too much is never enough!
All of about 2.8 seconds lol....a few fasteners and connector plugs is all there is to it...
09-20-2014, 08:02 PM | #9 |
One thing for the OP.... my very first tune attempt on my car, like two months after I bought it....produced that same message. I have since re-tuned and it has gone away. one of the biggest differences with the tunes is the amount of timing. The tune that produced the stabilitrak message had too much timing in it.
new tune...less timing and...No more Service Stabilitrak Message.
09-22-2014, 08:25 AM | #10 | |
09-23-2014, 11:28 AM | #11 |
I hope that helps....your problem does not quite sound the same, but they may have the same cause.
Keep us posted.
07-21-2017, 11:08 PM | #13 |
Drives: 2013 Camaro Ls Join Date: Jul 2017
This is exactly what is happening to my car! I have the vtc throttle controller, arh downpipes, and a custom catback exhaust system, did they do this job for you at the dealer?
07-22-2017, 06:53 AM | #14 |
Before you do anything else remove the VTC for a few days and see if that fixes it . There are lots of posts about VTC's not always being compatible with mods.
