![]() Drives: 2010 2LT Bumblebee Join Date: Apr 2013
3.91 Gear Swap Question
I am planning on swapping the stock 3.27 ring and pinion in my manual 2010 v6 to the 3.91. It seems that Motive and Richmond have a bad rep with their gears making noise, so I have narrowed it down between GM's 1LE 3.91 and Lingenfelter LPE 3.91
Just wanted to know your guy's experience with the 3.91 and what brands you guys use. I also have an IPF supercharger and I don't want 1st gear to be too short which is why I might do 3.70 instead
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
That first gear worries me on manuals, 4.46 or something, end ratio would be 17.5168, tire shredding ratio. You will need to be a good shifter and have great tires to get good times at the track.
What brand are you looking at? And ya I might be leaning towards 3.70
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
I have to swap out my entire differential, so I'm doing a 1LE differential with 3.91's from the factory. Any time you swap gears there is a chance of gear whine, can't be avoided.
Gears can be fun though if you don't mind the gas mileage drop. |
#6 |
Why is it that Lingenfelter sells 3.70 and Richmond 3.73?
#7 |
It's like how there's a 4.10 gear and a 4.11 gear. 4.10 is 41 teeth on one gear and 10 teeth on the other. 4.11 is 37 teeth on one gear and 9 on the other. So chances are 3.70 is 37 teeth and 10 teeth, while 3.73 is probably something like 30 and 8 or 33/34 and 9.
#8 |
Slow v6
Good luck on the swap! I had to do the whole diff because I am an auto, and went with 4.11. Love how it launches! If you have any questions pm me.
R.i.p gas mileage
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes USAF. Stationed in TX |
#9 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I have this whine when I am cruising around 4-45mphs...it starts when I lightly press on the gas but goes away once I accelerate.
#10 |
CodyBanks
Drives: 2011 Camaro Join Date: Aug 2012
Not familiar with gear upgrades. What does this do, how does it feel ect ?
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
A gear that is numerically higher (say a 3.91 vs a 3.27) is considered a "lower" gear. Let's call'em bigger gears.
You reach peak engine speed sooner (at a lower speed) with a bigger gear. This gives your engine a mechanical advantage and can allow it to accelerate more quickly than an identical car with smaller gears- even though the car's not producing anymore power. In short, when driving you'll reach higher RPM at lower speed. |
