Old 09-27-2014, 05:32 PM   #1
a7888ku
a7888ku's Avatar
Drives: 2013 Camaro 1LT
Catch can install
Just finished my Elite Engineering Catch Can. Digging it!!
a7888ku is offline   Reply With Quote
Old 09-27-2014, 11:17 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Now just don't forget to empty it
I'd lose the engine cover though.
TommyTheCat is offline   Reply With Quote
Old 09-27-2014, 11:31 PM   #3
crc91
crc91's Avatar
Drives: '14 1LS
I'm thinking of picking one up. How easy is the install? I hear its about the same as a cold air intake in regard to difficulty.
crc91 is offline   Reply With Quote
Old 09-27-2014, 11:33 PM   #4
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
Very easy... Pop off the engine cover, cut a couple hose and clamp on the new ones, bolt the can to the engine cover bolt (the one the the cover clips onto)
Old 09-28-2014, 12:24 AM   #5
crc91
crc91's Avatar
Drives: '14 1LS
Cool. So it comes with some really easy instructions?
Old 09-28-2014, 12:32 AM   #6
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
I'm pretty sure it came with instructions but I did not look at them lol
you take off the oil cap to remove the engine cover, put the cap back on
follow the hose that goes from the top of the intake and basically cut the middle section out. I actually did not reuse the piece that goes to the valve cover because the hose fits snug anyways but it would probably be better to reuse both connectors
you just leave a few inches for hose to go over the connectors and hook them up accordingly. attaches the bracket is really simple
you'll just need some pliers for the hose clamps, hose cutters, allens/hex socket for two of the screws to mount the can to the bracket unless you choose to use your own screws, and then a couple wrenches or 10 mm sockets
at least I think they were 10mm
also get some teflon and something to tighten up fittings where the hoses go on the can
Old 09-28-2014, 12:39 AM   #7
crc91
crc91's Avatar
Drives: '14 1LS
Thanks man I'll have to look at it tomorrow but I'm sure I can do it. If not there's enough ppl here running the elite can to get some help.
Old 09-28-2014, 04:53 AM   #8
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
If your interested, I made a video when I installed mine. Look up 2012 catch can LFX it should come up. It's about 15 mins long.
45thCamaro is offline   Reply With Quote
