10-02-2014, 12:28 PM | #1 | ||
Rim LED's rgb
I bought these from Gen5DIY and ended up going a different route with my ideas just trying to get most of my money back. I bought the RGB double strip LED wheel light kit for $349.99 and its brand new in box I would take $300 shipped.<br />
<br /> Glowing LED Multi-Color Wheel Kit<br /> <br /> Mounts Inside of the Wheel<br /> <br /> Water-Proof<br /> <br /> Easy to Install<br /> <br /> NO SOLDERING !!!!!<br /> <br /> <br /> <br /> You are looking at the best wheel lighting kit available – because it is installed INSIDE YOUR WHEELS. This is an RGB or color changing kit that bolts behind your brake rotor in a full circle of light.<br /> <br /> This kit is all inclusive! All you need are your wheels, tools and a little basic mechanical knowledge and you can install on any car. Yes – ANY car made! Kit is fully adjustable to fit whatever size wheel you have.<br /> <br /> Kit comes complete with well written instructions with photographs.<br /> <br /> Do they stand up to daily driving? The orange car pictured is mine and has had the LED-color wheels for over a year! <br /> <br /> Lights are water and weather proof. Mine have been through car washes, flooding and even Las Vegas summers! <br /> <br /> Nothing gets more attention at local cruise nights or at the drag strip.<br /> <br /> What You Get:<br /> <br /> 8 50 inch RGB color changing strips 60/M (highest # of LED's available) 5050 (brightest available)<br /> <br /> 4 50 inch adjustable circle brackets<br /> <br /> All brackets and hardware to install above<br /> <br /> 75 feet of wire<br /> <br /> Your Choice: Radio Frequency controlled RGB controller<br /> <br /> OR<br /> <br /> Powered Booster to add Color Wheels to an existing RGB system<br /> <br /> (specify which one you want when checking out)<br /> <br /> All crimp connectors for wiring (NO soldering required)<br /> <br /> Wiring Terminal Block<br /> <br /> 100 Zip Ties<br /> <br /> “Add a Circuit” fuse so no cutting of wiring <br /> <br /> Printed installation instructions<br /> <br /> Customer Service Phone Number for any questions<br /> <br /> See video links below<br /> <br /> http://youtu.be/EvW8ORLg1t8 <br /> <br /> <br /> <br /> “Anything you can imagine, I can design.”<br /> <br /> <br /> <br /> Car pictured does not come with kit, sorry. These kits are to be used in an “off road” or “show” type situation only. Please check with local laws before displaying this product on public streets and road ways. Display at your own risk.<br /> <br /> [IMG]http://www.gen5diy.com/image/cache/data/Door_Projectors/DS****67-600x600.JPG[/IMG]<br /> [IMG]http://www.gen5diy.com/image/cache/data/Door_Projectors/DS****50-600x600.JPG[/IMG]<br/> |
