Old 10-03-2014, 10:41 PM   #1
apr_gen5
Drives: 2013 ZL1 Yeh!
Stock ZL1brake pads on the track?
I signed up for a track day this weekend, which I planned to attend in my Z06. However, the Vette was waiting on parts that didn't arrive, so I am planning to take the ZL1.
Are the stock pads up for the job? There is only one long straight at the local track that doesn't have good run-off. I expect the zl1 will be at about 140 mph there and will have to slow to 60mph for the turn. I plan to lift early if the brakes are a problem. Thanks for any advice.
Tony
apr_gen5 is offline   Reply With Quote
Old 10-03-2014, 11:18 PM   #2
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
The pads are fine. It's the brake fluid that you should change. If it's your first time the stock set up will get you through. Remember it's not a race. Have fun and take some video.
Laus Deo
charlietuna is offline   Reply With Quote
Old 10-04-2014, 12:39 PM   #3
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
Yeah, definitely swap out your brake fluid to Dot4 which will withstand higher brake temperatures and remove brake fade. I use Motul RBF600. You will need three bottles for a flush.
http://www.amazon.com/gp/product/B000AURZ08/
Hope you enjoy it.
Expunge is offline   Reply With Quote
Old 10-04-2014, 07:19 PM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Agree with others change the fluid, stock pads won't give you problems, especially if you are on stock tires, but they take a lot more pedal pressure than some of the racing pads out there. Have fun!
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
