SOLD!!!! SUMMIT WHITE INTERIOR KIT DOOR AND DASH INSERTS
Sold!!!!!
Res Ipsa Loquitur
Drives: 2013 Camaro SS Vert Supercharged Join Date: Sep 2012
I'm interested! Now that you sanded and polished the dash inserts, does it require ABL through the dash or will it look ok if ABL is not installed? I Wasn't planning on adding ABL to the dash. Also, do the door inserts have or allow for ABL?
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
The door panels do allow for the abl and that is where I sanded to make the light go all the way to the dash. I started to sand and polish the small side of the dash insert so I could later add the dash abl but changed my mind.when the piece is installed you can't tell.
This is the back side of the small piece
