Old 10-07-2014, 06:25 PM   #1
crc91
crc91's Avatar
Drives: '14 1LS
Exclamation Need opinions on FI option
I'm looking into this for my dad. He has a 2010 2ss/rs L99 camaro. He's looking for advice on going the supercharger route. He wants a procharger kit either the high output kit with a snow meth kit or the procharger stage two kit. Which would make more power? Which would you guys go with and why? Looking for all the info I can on this. Thanks in advance guys!
crc91 is offline   Reply With Quote
Old 10-07-2014, 06:29 PM   #2
AGP Turbo
Drives: All things Turbocharged
Why Procharger over ECS?
AGP Turbo is offline   Reply With Quote
Old 10-07-2014, 06:46 PM   #3
pincushin3819
pincushin3819's Avatar
Drives: 11 AGP TT SS, 14 ECS C7
The real question is why Procharger or ECS over AGP
pincushin3819 is offline   Reply With Quote
Old 10-07-2014, 06:48 PM   #4
crc91
crc91's Avatar
Drives: '14 1LS
It's what he wants, what are the advantage of the ecs kit over the procharger? (Ecs uses a vortech head unit correct? So it can't be too different)
Old 10-07-2014, 06:50 PM   #5
crc91
crc91's Avatar
Drives: '14 1LS
He wants a sc centri setup
Old 10-07-2014, 06:54 PM   #6
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
When you think centrifugal superchargers, the first thing that should come to mind is Vortech! I've got some information my thread here that you can read about - http://www.camaro5.com/forums/showthread.php?t=313352
With the right mix of mods, this can be achievable on their competition blower.
If you're looking for a complete kit the V3si blower which comes standard in their complete kit would be a good option with 581HP and 517Ftlbs of torque at your disposal with a smooth easy powerband to work with as well.
ModBargains.com is offline   Reply With Quote
Old 10-07-2014, 06:57 PM   #7
pincushin3819
From what I've read ECS is cheaper, better base head unit, better intercooler, better brackets & customer service.
Old 10-07-2014, 07:19 PM   #8
crc91
crc91's Avatar
Drives: '14 1LS
Let me make this clear guys, he wants a procharger h/o with the snow meth kit or the procharger stage 2 kit. This is what he wants to go with end of story, what would you guys pick and why? What power output can I expect out of both set ups? What kinda boost number would we be seeing? Again it's a 2ss 2010 L99
Old 10-07-2014, 07:53 PM   #9
AGP Turbo
Meth injection doesn't go so well with the mild steel pipes in the procharger kit. Not sure if they have changed that or not.
Old 10-07-2014, 07:57 PM   #10
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
He will want to go with the Stage 2. You get a better intercooler and race valve. If hes just looking to make around 600hp then the D1 will be plenty. But if he's like most and will want more power later get the F1A. Lot cheaper to upgrade now then later and have to buy a new blower. As for boost numbers that will depend on what pulley you go with.
Nitroman28 is offline   Reply With Quote
Old 10-07-2014, 10:02 PM   #11
crc91
crc91's Avatar
Drives: '14 1LS
What numbers could we expect with the reg procharger kit plus meth compared to the stage 2 procharger kit? (Both with the regular pulley )
Old 10-07-2014, 10:27 PM   #12
Midnite Magic
Drives: 2013 ZL1
The cold hard facts are the procharger kits have a few problems on the Gen 5 Camaros that lead to less than stellar performance when compared to the Vortech V3-Si kit. First one being the intercooler in the HO kits. It is a joke and barely cools 4-5 psi of boost. If you like 160-170° intake air temps this is the kit for you. The larger intercooler in the Stage II kit does okay but then you need to deal with the issue of the air intake being right above the exhaust manifold or header. The Stage II kit is OK but I would recommend upgrading the the P1SC-1 to D1SC right away along with wrapping the exhaust header/manifold. Also methanol on the procharger steel piping is not that great. I guess it comes down to how much power and money he is looking to spend. The Stage II kit with D1SC pulled for 8 psi will make good power without methanol on pump gas. Plenty of other option like the AGP twin turbo kit, Turbonetics single kit or a TVS2300
Midnite Magic is offline   Reply With Quote
Old 10-07-2014, 10:53 PM   #13
crc91
crc91's Avatar
Drives: '14 1LS
Thanks for the input I'll let him read this. Keep it coming guys the more info I have to give him the better! Anyone else?
Old 10-08-2014, 12:57 AM   #14
Midnite Magic
Drives: 2013 ZL1
Guess you also have to ask yourself how you are going to use the car? If this is an around the town stoplight pounding machine nothing is going to beat a positive displacement blower in torque and acceleration from a light with an automatic. The Vortech and Procharger will be faster on the top end but the amount of low RPM torque the TVS2300 makes once that bypass valve closes makes most people smile. I would rather have 40-50 more ft. lbs. than 20 more HP at peak RPM. It is all about area under the curve
