Old 10-09-2014, 11:17 PM   #1
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
HELP!!! Intermittent DTC P0116
Hello all. I am getting an intermittent P0116 on my 2012 SS, LS3. It usually happens once every drive cycle, about 10-15 minutes into the drive. I have an "ultra-gauge" as well, that monitors coolant temp also. I figured it was the ECT sensor in the head starting to fail, so i replaced it with a new one. No luck still get the code. The car is not getting hot, as the ultra-gauge never shows coolant temp over 190*F. The car has a Whipple, LS9 cam, LT's, custom tune, and has been this way about 18 months. Anybody have any ideas?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 10-09-2014, 11:21 PM   #2
Batmanntexas
Update: I drove the car to work this morning, as usual, however, I disconnected the ultra gauge and ran my Actron scan tool in it's place. I set it to monitor coolant temp (PID mode). Code P0116 popped on about 10-15 minutes into the drive, and water temp was 185-188*F. I pulled over and attempted to look at the freeze frame data, but there wasn't any in memory. Anybody have any ideas? Anybody?
COTW 9/8/14
Old 10-10-2014, 06:32 AM   #3
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I found this, hope it helps.
Trouble Code: P0116
ECT Sensor / CHT Sensor Signal Range/Performance
Possible Causes:
Check for low coolant level or incorrect coolant mixture
CHT sensor is out-of-calibration or it has failed
ECT sensor is out-of-calibration or it has failed
P0116 - OBD-II Trouble Code
Auto Systems and Repair
Engine Coolant Temperature Circuit Range/Performance Problem
Our emissions expert has put together the following information about the P0116 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
OBD II P0116
Fault Code Definition
What does Mean?
The Engine Coolant Temperature Sensor measures the rise and fall of the Engine Coolant Temperature. This provides critical data needed for the Powertrain Control Module (PCM) to control the Air Fuel Ratio, the Ignition Spark Timing, the cooling fans, and many components of the Emissions Control Systems. The Engine Coolant Temperature Sensor converts the coolant temperature into a voltage that is high when the engine is cold and low as the engine warms up.
Code P0116 is set when the Powertrain Control module sees irrational out of specification voltage signals from the coolant temperature circuit.
Symptoms
Check Engine Light will illuminate
In many cases, no abnormal symptoms may be noticed
In some cases, the engine may be hard starting and/or get poor fuel economy
Common Problems That Trigger the P0116 Code
Defective Engine Coolant Temperature Sensor
Rusty and/or corroded Engine Coolant
Faulty or corroded Engine Coolant Temperature wiring or connections
Common Misdiagnoses
Engine Coolant Temperature Sensor is replaced when the real cause is rusty coolant
Engine Coolant Temperature Sensor is replaced when the real cause is a poor connection or chafed wiring
Engine Coolant Temperature Sensor is replaced when the real problem is in the Cooling System
Polluting Gases Expelled
HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
CO (Carbon Monoxide): Partially burned fuel that is an odorless and deadly poisonous gas
NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog
P0116 Diagnostic Theory for Shops and Technicians
When diagnosing a P0116 code, it is important to record the freeze frame information and then to duplicate the code setting conditions with a test drive while paying close attention to engine load, throttle position, RPM, and road speed on a data streaming scan tool. As you drive the vehicle, compare these values to the Coolant Temperature Sensor PID or parameter ID. The Coolant Temperature Sensor voltage values should rise and fall with changes in engine temperature. Compare the Engine Coolant Temperature or ECT readings to the Intake Air Temperature Sensor readings, as they should move in tandem with each other. However, the Engine Coolant Temperature sensor will have a much higher temperature range.
Check the ECT sensor connector with the key on and the engine off. There needs to be a steady 5 volt reference voltage and a very good ground. Find and use the proper engine performance wiring diagram to discern the proper color and position of these wires in the connector.
It never hurts to do a key on-engine off voltage output test of the ECT sensor. Typically, I CAREFULLY use a heat gun to raise the temperature of the area around the sensor and study the change in values of the Coolant Temperature Sensor circuit. It's important to use the scan tool data stream as this will verify the ECT harness and connections.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 10-11-2014, 11:45 AM   #4
izaks
Drives: Chev Lumina 416
If you fitted a lower temp thermostat - P0116 will set (and disable your A/C)
Switch P0116 and P0128 off in the tune
izaks is offline   Reply With Quote
dtc, ect, intermittent, p0116
