Old 10-10-2014, 12:19 PM   #1
rico-2SS
Thx TZD.
rico-2SS's Avatar
Drives: 2010 Supercharged Custom Camaro
Axle Noise??? 2010 custom
HELP!!!!!!
A little over a year an a half ago I had to put new axles in the Camaro. In the last month coming from the driver side there is a rotation clicking and or clunking noise. I think its an axle as when you push in the clutch the noise seems to go away. So its only under power we hear the "noise"
The thing is it didn't do it all the time. Seems to come on after some tight corners or aggressive driving (on closed roads of course).
Anyway......anyone have this happen and or know what it could be???? Something loose or do I have a bad axle?
Thought I would throw this thread out there before getting the car in the air and getting under there to look or start tearing things apart.
Spike you out there my friend
In many cases this isn't even keeping up with the Jones's, this is Jonesing and just plain KEEPING UP!!!
rico-2SS is offline   Reply With Quote
Old 10-10-2014, 12:27 PM   #2
H-E
Drives: 2010 zr1 Camaro 2011 vert
You need to check for grease slinging.With a lose clamp or a split in the boot you could have lost your grease and wore the cv down.If you need any parts give me a call.If need be we can rebuild your cvs
H-E is offline   Reply With Quote
Old 10-10-2014, 12:36 PM   #3
rico-2SS
Thx TZD.
rico-2SS's Avatar
Didn't see any of that (grease) upon just ground inspection and looking under but when I get her in the air I will look harder.
They stock axles where replaced with ones rated up to 1000 hp. Still be able to help if needed?
BTW thanks!!!!
Old 10-10-2014, 12:51 PM   #4
H-E
BTW thanks!!!!
Yes sir no problem. .980 521 0722 call anytime and we will figure out what we need to do.
Old 10-10-2014, 12:57 PM   #5
rico-2SS
Thx TZD.
rico-2SS's Avatar
thank you
Old 10-10-2014, 01:51 PM   #6
H-E
thank you
No problem. ..like I said call anytime I answer every day..
Old 10-10-2014, 02:15 PM   #7
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Does yours have the thrust washers? My 2010 didn't come with them and I had a clicking sound. Put some in and noise was gone.
Nitroman28 is offline   Reply With Quote
Old 10-22-2014, 03:59 PM   #8
rico-2SS
Thx TZD.
rico-2SS's Avatar
That's what it was. Dealer tried to tell me we didn't install them when I but the new axels in. I was not happy it cost me $$$ but its running great now.
