Old 10-12-2014, 01:31 AM   #1
William.23
William.23's Avatar
Drives: 2011 Summit White.
Highest Gear on stock v6?
Hey there just wondering what's the highest gear I could put into a V6 without converting it to the 9" rear kit ? just STOCK.
Of course this is for an A6.
Appreciate the feedback as well as time and patience.
William.23 is offline   Reply With Quote
Old 10-12-2014, 10:16 AM   #2
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
If you have an auto, it does not have LSD. Best bet in the long run is to do a full differential swap. The lowest gear for the a6 is going to be the 3.55's, but you will still be one wheel peeling it.
Good luck!
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 10-12-2014, 05:34 PM   #3
William.23
William.23's Avatar
Good luck!
Appreciate it just wondering before I go with a close to $5000 diff swap.
Think I can just get it from a salvaged A6 SS and swap it onto mine? Would probably come out cheaper like that.
Old 10-12-2014, 07:52 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
That would give you the same gears. Go for an M6 SS differential - it has the 3.45 gears. Small upgrade but worth it if you're going to go boost later.
DSX_Camaro is offline   Reply With Quote
Old 10-13-2014, 02:05 AM   #5
qsaoyueshs
Drives: camaro
qsaoyueshs is offline   Reply With Quote
Old 10-13-2014, 08:41 AM   #6
10RsCamaro
Slow v6
10RsCamaro's Avatar
It will still be the same gearing you have, the 3.27, but you will have a LSD. If you do that, grab some gears and get them in. If you are able to grab one used, you can do everything turn key for 2k
Good luck!
