Old 08-18-2009, 09:27 PM   #1
ALLT4
ALLT4's Avatar
Drives: 2010 Camaro 2SS RJT
Defrost Vent always on.
Anyone else notice even if you have the A/C selected to come out of the floor or just out the vents some still comes out of the defrost vent? It gets to be a problem in real humid weather after a rain, you have to run the wipers to keep the fog cleared off the outside of the window. I think if you select vent only, it should vent only right? Now it's not giant deal breaker just an observation that should be corrected in the next years model.
I don't post this because I'm continuously bashing the car, I post it because if enough people point it out it will be corrected in the next iteration of the car. And don't tell me all cars do it, they don't, I have 4 other cars that are not a problem.
ALLT4 is offline   Reply With Quote
Old 08-18-2009, 09:43 PM   #2
drifter73
Drives: 2010 RJT 2SS w/ black rallys
Haven't noticed that yet on my Camaro, but I have the same problem on an Impala I rented recently. It can be annoying, for sure.
drifter73 is offline   Reply With Quote
Old 08-18-2009, 09:44 PM   #3
BamaCommando
Roll Tide Roll!
BamaCommando's Avatar
Drives: 2010 2SS Black on Black
This is one thing we noticed the first evening we got it. It was fogging the windshield and we couldn't get it to stop.
Order number NGCC3D
1100 (Preliminary order accepted): 12/19/08
3000 (Order accepted by production control): 6/30/09
3100 (Order available to sequence):?
3300 (Order scheduled for production):?
3400 (Order broadcast):7/20/09
3800 (Order produced):7/28/09
4200 (shipped):7/30/09
HOME 8/12/09
The slowest 7 months and 3 weeks in history.
BamaCommando is offline   Reply With Quote
Old 08-18-2009, 09:47 PM   #4
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
G6 does the same thing, major PITA!! If there is the slightest bit of humidity you either have to run the air or defrost to equalize the temperature of the glass I guess, even if the windows are down.
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Old 08-18-2009, 09:52 PM   #5
ALLT4
ALLT4's Avatar
The A/C being on is what the problem is to begin with, the defrost vent blows cold air out regardless where you have selected the air to exit. To an extent anyway, it never fully closes down. Tonight driving around in the humid damp air the cooling effect on the glass near vent causes condensation to form on the outside of the glass. If the defrost vent would fully shut down it wouldn't be a problem.
Old 08-18-2009, 10:22 PM   #6
Betro02
Betro02's Avatar
Drives: Powerful
Just like in your signature.
Betro02 is offline   Reply With Quote
Old 08-19-2009, 01:05 AM   #7
CamaroSS_LS3
CamaroSS_LS3's Avatar
Drives: 2010 Camaro 2SS/RS IOM/IOM 6M
Yes mine does this too and it is a PITA.
2SS/RS 6 speed manual. VIN# 2G1FT1EW7A9116851
No Mod's love it just the way it is.
CamaroSS_LS3 is offline   Reply With Quote
Old 08-19-2009, 03:29 AM   #8
djsnoflake
Faith Keeper
djsnoflake's Avatar
I run my A/C to stop the windows from fogging because the A/C also de-humidifies. I just don't set it to max cold mode. Even if you have your temperature set to the 'hot' side of the scale, you can have your A/C on while you do it to use it as a de-humidifier
Old 08-19-2009, 07:17 AM   #9
ALLT4
ALLT4's Avatar
That's not the problem djsnoflake, the condensation is forming on the outside of the front window because the A/C never stops fully blowing out of the defroster. There's none on the inside. It cools the glass right there and if it's really humid and damp out you get that fog that has to be wiped away with the wipers.
Old 08-19-2009, 07:57 AM   #10
barking tires
Supercharger
barking tires's Avatar
Drives: 2SS Camaro
Same problem here, when its in the 70's and the humdity is 89% at night the last thing we need is the cold air hitting the glass all the time. And if you turn the air off or down it is instant sweat.
barking tires is offline   Reply With Quote
Old 08-19-2009, 08:21 AM   #11
aircooled
Drives: 2005 Chevy Cavalier
I have the same problem on my Cavalier but if I take it off max cool (ya know the one with the u shaped arrow at least on my Cavalier it is) the fogging problem disappears. If i remember correctly the reason it does that on max cool is the air within the car is recycled completely and the air is pulled in @ the defrosters then blown back out thru the vents, whereas with any of the other A/C selections the cooled air is a mixture of inside and outside air.
aircooled is offline   Reply With Quote
Old 08-19-2009, 08:59 AM   #12
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
have same problem with my Equinox....Must be a GM FEATURE
Moorepheus is offline   Reply With Quote
Old 08-24-2009, 08:13 PM   #13
Bigwood
Drives: IOM 2SS/RS Manual
Same problem here, found it helps if you don't use recirculate and and one notch off of max cold
Bigwood is offline   Reply With Quote
Old 08-24-2009, 10:47 PM   #14
ALLT4
ALLT4's Avatar
Yeah Bigwood, I forgot about this thread, thanks. That's pretty much the same fix I've found, just a few clicks above total cool side, still cold enough to keep you cool but not cold enough to cause the condensation on the outside of the window.
Whistle from the vent blower motor Big_T Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 43 02-28-2012 11:07 AM
Vent Guards Pope Designs 5th Gen Camaro SS LS LT General Discussions 27 07-16-2009 05:55 PM
Side vent highlights Ristaze Cosmetics and Lighting Modification Discussions 14 07-02-2009 12:07 AM
OK my reason to vent.. VERY off topic... lordfriday2 Off-topic Discussions 21 11-27-2008 10:48 PM
