Old 10-12-2014, 09:33 PM   #1
Allmotor1313
Drives: Chevy Camaro 2013 ZL1
ZL1 pulley upgrade
Want to upgrade the upper pulley for more boost. Is there a pulley that I can use that will not require injectors? What else will need to be upgrade to run that pulley?
Allmotor1313 is offline   Reply With Quote
Old 10-12-2014, 09:38 PM   #2
AbsolutHank
AbsolutHank's Avatar
Drives: 2016 Corvette Z06 M6
Some guys run a 2.5 upper pulley and a CAI on stock injectors, but I really think you should wait until you have the cash for injectors too. Once you crossed that line and mod your car eliminating your warranty, a little extra peace of mind will go a long way.
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero
AbsolutHank is offline   Reply With Quote
Old 10-12-2014, 09:44 PM   #3
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Why do the upper pulley? If you do the lower you have more pulley size options and it looks less obvious that it was changed. It is also much easier to install IMO
Jannety does the 10% OD lower pulley without a tune (use torco)
2013 ZL1 #7860 is offline   Reply With Quote
Old 10-12-2014, 10:07 PM   #4
Allmotor1313
So with the jannety lower pulley I can install without a tune? How much more will it boost?
Old 10-12-2014, 10:31 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
It doesn't what set-up or brand you use or who you buy from. But if you go over about 10% overdrive you'll need injectors.
You basically have two choices. Metco/Innovators West or ATI. Different vendors sell one or the other. Both do the same job.
http://www.metcomotorsports.com/prod...CP-LSA&cat=118
http://www.atiracing.com/products/da...serp.htm#Zbody
Here you see all the pulley sizes(CTS-V is the same as your ZL1)
http://www.atiracing.com/products/da...mserp.htm#CTSV
Check the classsified section over at the CTS-V forums.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-13-2014, 11:17 AM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I think you will be about 10.5-11psi or so. mine was 11.8-13 through the band but that was with rotofab installed which adds about 1psi boost.
HP wise the 10% lower and no tune is the proabably the most HP you can add in a single mod without doing anyting else.
I reall like having a CAI on as well to hear the supercharger a bit but at that point you would need a tune or more octane.
2016 2SS
2020 super duty on 37's
hognutz is offline   Reply With Quote
Old 10-13-2014, 11:27 AM   #7
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I would highly suggest not doing any pulley upgrade until you get injectors. With just a Roto-Fab intake, polished TB & Headers my duty cycle was around 86% I swapped out to ID850's before I did my upper.
If you run a different pulley (upper or lower) you're on borrowed time IMO.
BaylorCamaro is offline   Reply With Quote
Old 10-13-2014, 11:28 AM   #8
Allmotor1313
Right I have a roto fab intake, kooks headers and full exhaust running 93 octane
Old 10-13-2014, 12:54 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Bone stock my car was at 93% duty cylcle. At 6200 rpm. Did you take yours to redline when you checked.
Bryan 2018 ZL1 M6
Old 10-13-2014, 12:56 PM   #10
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Yes, I forgot what it was at Red line, but we pulled red line down to 5900 rpms where duty cycle was high 80s. I imagine it was low / mid 90s at 6200.
Old 10-13-2014, 02:48 PM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I have stainless works headers, 10% lower, rotofab intake stock injectors.
just make sure you datalog the car. the injectors will be pretty maxed out though but it is not 100% required to have to change them. seems like it can vary a bit car to car. I will add injecotrs this winter though. it is something that if you do anyting else to the car you will need them for sure.
2016 2SS
Old 10-13-2014, 02:52 PM   #12
Allmotor1313
Sounds good did you do the install yourself? If not how much did you payfor the labor?
Old 10-13-2014, 04:58 PM   #13
CRTZL1
Banned
Drives: 2013 CRT ZL1
Subscribed!!
Sent from my SM-N900V using Tapatalk
CRTZL1 is offline   Reply With Quote
Old 10-13-2014, 10:15 PM   #14
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I did it myself the lower is very easy to do 2-2.5hrs. you need a 3 jaw puller you can rent if you don't own one. you need a toque wrench and a longer bolt or piece of all thread to press the dampner on.
I am sure a shop might ding you $150-200 though.
if you do it yourself buy the ARP balancer bolt it is toque to value instead of torque to yeild. I have done it both way and the torque to yeild sucks.
2016 2SS
