Old 10-13-2014, 07:12 PM   #1
B&MRacing
B&MRacing's Avatar
Drives: 2016 Camaro SS
B&M GM LSx SFI Flexplate: Fits GM LSx Type Motors 2010 and newer
Part #20340
Fits GM LSx motors including 2010 and newer automatic Camaro with L99 engine and 1st through 4th generation Camaro's and Firebird's. Also fits all GM LSx motors using an automatic transmission including Corvette, GTO, and G8. SFI 29.1 approved and legal for all NHRA/IHRA classes. Ideal for street applications to extreme duty racing and high RPM use(above 6,000 RPM). B&M's new Radial Tension Technology puts a new spin on flexplate technology. As engine performance levels increase, stronger flexplates become necessary. Until this point, stronger flexplates meant thicker flexplates. This works, but it adds unwanted weight and prohibited the flexplates from working as it was designed. Flexplates are designed to provide a protection against converter and transmission run out or OEM misalignment, which will cause transmission and/or converter failure. A rigid flexplate gives no protection. The ultimate design for a flexplate is extreme strength, flexibility and minimal weight. B&M's new RTT performance flexplate accomplishes this goal. B&M's design allows for the removal of unnecessary material from noncritical stress areas. Less material means less weight giving you the benefits of a lightweight, flexible design with thicker material for maximum strength!
Features and Benefits:
SFI 29.1 Safety Rating
Steel
One piece
Balanced
Sold Individually
Specifications:
Crankshift Bolt Hole Count: 6
Flexplate Outside Diameter (in): 14.13
Flexplate Weight (lb): 6
IHRA Legal: yes
NHRA Legal: yes
SFI Approved: yes
SFI Certification Sticker: included
B&MRacing is offline
b&m, converter, flexplate, lsx, transmission
