Old 10-14-2014, 12:29 AM   #1
batone
2012 2SS/RS vert 6spd
batone's Avatar
Drives: 2012 Convertible SS/RS
ACS ZL1 insert
Just installed my ZL1 bumper, hood and ACS insert. When I tried to install the water deflector, it is hitting on part of the air box and hood will not close. Left it off for now, can someone tell me what I am missing?
batone is offline   Reply With Quote
Old 10-14-2014, 02:32 AM   #2
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
Are u sure u have the one for the ss and not the zl1? They sell both.
Johnthegreat is offline   Reply With Quote
Old 10-14-2014, 06:01 AM   #3
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
The TL1 (ZL1 Insert) for the stock V6/V8 hood comes with a flat water deflector that should not hit. (Photo 1)
If you have the ACS ZL1 insert (the one for the OEM ZL1 hood) you have the ZL1 water deflector (2nd photo).
If you have the 2nd water deflector have you tried to remove your stock engine cover and see if it hits?
I had the ACS TL1 insert for the stock V6/V8 hood I had the ZL1 water deflector installed (see pic # 2 this is my hood) I had a slight rubbing against me OEM engine cover but it closed with no issues.
If you have the ZL1 water deflector and need the flat ACS one let me know I have mine I never used I can sell you cheap.
Thanks
Sean
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 03-14-2016, 09:47 AM   #4
Xiclutchz--
YG.Trece
Drives: Chevrolet Camaro z28 2015
Zl1 fiber glass hood insert
Can someone tell me if I will be able to cut out my Rs hood to install the zl1 insert ? Or do I need zl1 hood
Xiclutchz-- is offline   Reply With Quote
Old 03-14-2016, 02:46 PM   #5
01pewterz28
#TeamBeckyD
That looks like a fiberglass ZL1 insert for the OEM ZL1 hood. That will not work due to the mounting pads on that insert it's made for the indents in the ZL1 hood. You need the actual TL1 insert fro ACS.
#TeamBeckyD
Old 03-15-2016, 08:44 AM   #6
Xiclutchz--
YG.Trece
Could I just remove the mounting pads or will that damage it
Old 03-16-2016, 08:42 AM   #7
01pewterz28
#TeamBeckyD
I have no clue on that it's a 50/50 shot the other thing you need is the mounting hardware and template to cut the hood.
#TeamBeckyD
Old 08-13-2016, 02:26 PM   #8
Xiclutchz--
YG.Trece
Still have that water deflector ?
Old 08-13-2016, 02:53 PM   #9
BLU DUCE
BLU DUCE's Avatar
You people just better make sure you have all the right parts for what ever car or hood your putting this on before doing any cutting.
Old 08-13-2016, 05:30 PM   #10
GetYouOne
Drives: 2012 2SS/RS
Ur ZL1 ACS hood water drain should not be hitting anything. I had to trim mine because I had a Rotofab radiator cover that was the only issue. When I got my turbo I had to leave it off because it hit my down pipe. Still looked good.
GetYouOne is offline   Reply With Quote
Old 08-16-2016, 07:14 AM   #11
Xiclutchz--
YG.Trece
Can someone tell me what I can use instead of a water deflector ? Can I make my own water deflector ? Or is there a way to cover the holes ? I have v6 so I don't care much about air flow just looks
Old 08-16-2016, 04:33 PM   #12
01pewterz28
#TeamBeckyD
You can do what ever you want they give you one to just deflect the water. If you need the TL1 ACS one (the one that comes with it) I have mine I never used (not the ZL1)
#TeamBeckyD
Old 08-19-2016, 03:47 PM   #13
Xiclutchz--
YG.Trece
How much ? And I was asking cause I bought zl1 hood and insert but no water tray or deflector so I'm lowkey scared to drive with out it but everyone tells me that engines can get wet and that people drive camaros with the insert daily with out water tray and no problems so idk what to do
Old 08-19-2016, 05:55 PM   #14
GetYouOne
Drives: 2012 2SS/RS
You'll be fine I drive mine without the water tray
