![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Dynatech Super Cats for Super Charged cars
Almost 2 years ago I approached Dynatech to make a set of cats that would live in supercharged applications, and they are finally here.
At nearly twice the size and better materials we are excited to start using them. Available as a direct replacement for current Dynatech cats or off road pipes. Available in both 2.5 inch outlet and 3 inch outlet versions. For those who with superchargers that don't want the Stink of off road pipes you now have an Option. We will be including these in our Header kits for all supercharged applications when ordering. In stock Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra Join Date: Nov 2009
do these require cat over temp to enrich to near oem levels for them to live? have there been any testing on these cats?
#3 | |
They have been testing them for over a year that is why it took so long. I just received the first batch.
![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 Join Date: Aug 2009
ARH
![]() Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
#6 |
Ok but if something went wrong they won't be covered by warranty after cutting them ?
Ahmad
#7 |
Correct.
#8 |
Ted, I have Dyna-tech headers and high flow cats that I got from you. What would be the difference? Also the cats that I have now, how long should they last at 600 rwhp?
#9 | |
Some last a lifetime some last a day at the track. Periodic inspection is recommended. Ted.
#10 | |
So by inspecting them you mean removing them for inspection? If one or even both fail will or can it cause damage and would it not throw a code If it let go? Thanks |
#11 |
![]() Drives: 2014 ZL1 M6 Join Date: Jul 2014
What would be the fit up problem with these and ARH LTs?
What is different about these and ARH high flow cats? Tony
2014 ZL1 M6
Bone stock, for now! 2001 Z28 M6 !cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB !4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners! 352rwhp and 366rwtq |
#12 |
![]() Drives: 2013 IFO ZL1 Join Date: Dec 2013
How did they test them?
What mods did the cars have that they tested them on? |
#13 | |
Unfortunately No many people have found destroyed cats with no indication there was a problem. Ted.
#14 | |
Ted.
