10-16-2014, 09:36 PM | #1 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
1LE Caster vs SS
So I can't figure out how the FE6 has 5.6 degrees of front camber vs 5.8 on the standard SS. Is this a difference in the radius arm bushings? Its not a lot of difference, but clearly Chevy thought the change meaningful enough.
Anyone know how there is a different spec for the 1LE since caster is not adjustable? Not sure if the different wheel size would translate to caster.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
10-16-2014, 11:17 PM | #2 |
Try this set up !
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
10-18-2014, 07:12 PM | #3 | |
Drives: 2010 IOM 2SS/RS Join Date: Sep 2014
As the strut travels from full jounce to full rebound, it travels through an arc. The arc is determined by the geometry of the ride and handling links. As you travel further into jounce, both caster and camber change as you travel along the arc. IIRC, the front springs on the 1LE have a lower check height than the standard SS springs. That will cause the car to sit a little bit lower. In the range we are talking (near static curb height), camber and caster are increasing as the car gets lower. That means that the car is sitting further into jounce, so caster and camber will be greater than if the car was sitting at the standard SS front height. The increased camber can be adjusted out using the strut adjustments (upper strut to knuckle hole is slotted), but the caster cannot be adjusted out (due to the lack of caster adjustment), so the "correct" caster for the 1LE is a little greater than the "correct" caster for a standard SS. |
10-20-2014, 02:41 AM | #4 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
10-21-2014, 09:30 AM | #5 | |
